Originally Posted by dmcgaugh
Hi folks, I’m planning to install a BMV-712 in my 2017 30 International.
I recently became aware of the pre-wire cat5 that sits behind the Sea Level sensor in the galley wall. And I intend to use this for the monitor.
I’ve not been able to confirm though where the other end of the cat5 is in my trailer. I somewhat assume it is behind the converter (under the fridge), but don’t know for sure. Can anyone confirm?
Then also, does anyone have a best practice for locating the shunt inside on the 30 International? I somewhat assume putting it inside the small street side storage compartment under the L-lounge makes the most sense.
On our 2016 30 international we put two 100Ah BB LiFePO4 and all the other related hardware including the BMV-712 shunt under the driver side L-lounge/couch in the front of the trailer.
Since we were no longer using the factory solar controller we removed the display in the galley and put the BWV-712 display in its place. To this end we had to splice the stock 4 pair communication cable (you call this the pre wire cat5) that went to the old controller to match the 3 pair comm cable used by the BMV-712.
The other end of the 4 pair comm cable (cat5) goes from the galley to the rats nest in the very front of the trailer. Look under the L shaped couch thing for the nest. There is a board on which is mounted the use/store relay, the 7 wires from the TV, the ground and 12V buss bars, and the solar controller thing.
The 4 pair comm cable (cat5) plugs in to the solar controller thing.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
