Old 09-21-2016, 03:51 PM   #57
Brav's Avatar
2016 25' International
Huntington Beach , California
Originally Posted by golfarch View Post
Brav:
Where did you find the 'CODE' for the VE Direct to finish the iphone app installation? I can't find the 'CODE' anywhere. It appears to be numbers only?
Should be 000000 by defualt? for bluetooth?
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Old 09-21-2016, 06:34 PM   #58
lewster's Avatar
Naples, FL , Hood River, OR
Right. When asked for a PIN, enter 000000, which is the default for all VE setting. You can change it later if you desire in the settings section.
Lew Farber
Old 09-22-2016, 07:49 AM   #59
golfarch's Avatar
2007 27' Classic FB
Myrtle Beach , South Carolina
Lew:
Yesterday I had a technician instal the following: Victron BVM-792, Victron VE.DirectSmart dongle, two new 12V 27 AGM Dual Marine Batteries (20 ah Capacity each), and a Progressive Dynamics PD4600 Series Converter.
Batteries were fully charged and turned on LED ceiling lights and the Monitor indicated that I had 4.6 AH remaining on batteries. After two hours with ceiling lights on, the battery monitor indicated 67 percent battery capacity left and about 1.34 hours left on battery life.
I shut everything off and this morning I checked the monitor and it indicated that the batteries had 39 percent charge left.
This is not right. I must have a short or some bad connection that is draining the batteries. Should the battery monitor at least start with 19 hours of charge remaining after just a few minutes using only 1.6a?
Something is not functioning properly.
I don't know how to resolve this.
Where do I start?
Lew Farber
"The Percolator"
golfarch is offline   Reply With Quote
Old 09-22-2016, 08:25 AM   #60
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Huh? I thought a Group 27 AGM was about 90 AH capacity. Did you set up your battery monitor with the right amp-hours?
Larry
lsbrodsky is offline   Reply With Quote
Old 09-22-2016, 08:53 AM   #61
golfarch's Avatar
2007 27' Classic FB
Great question. I erroneously used 20 hr for capacity instead of 90ah.
How did I get two college degrees?
"The Percolator"
Old 09-22-2016, 09:06 AM   #62
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
What's the actual voltage at the battery terminals?
OTOH, sounds like that technician needs to come back with an ammeter, among other things, to figure out what's going on and get it properly sorted.
Also - when you refer to hours remaining, do you mean amp-hours? That number didn't sound right either.
Rocinante is our 2014 International Signature 27FB
Rocinante is online now   Reply With Quote
Old 09-22-2016, 10:00 AM   #63
golfarch's Avatar
2007 27' Classic FB
Larry:
I reset the monitor to 90 ah and the entire system is functionin gperfectly.
With 0.80 A usage it now indicates that I have 3 days and 5 hours! That's better.
Wrong capacity set everything into 'helter skelter'. Now have proper readings.
Thanks. Very Much.
"The Percolator"
Old 09-22-2016, 10:04 AM   #64
golfarch's Avatar
2007 27' Classic FB
I reset the monitor to 90 ah verses 24 and the system is now reporting proper numbers.
The wrong 24 ah capacity was wrong. It was not reading anything properly. The batteries were not at 36%. They fully charged in less than 2 hours and the time remaining now indicates 3 days and 5 hours with 0.80 A usage. Much better.
Thanks.
"The Percolator"
Old 09-22-2016, 10:28 AM   #65
lsbrodsky's Avatar
Yeah, but if you have 2 of those batteries in parallel, you have 180 AH of capacity and you do not want to draw them down to more than 90AH left, 50%.
Larry
Old 09-22-2016, 10:42 AM   #66
lewster's Avatar
The BMV-702 should be set for your total battery capacity. I would also check the 20 hour rating on the battery label, as most Group 27s have seen are rated at 100 amp/hours.......giving you a total of 200 amp/hours of capacity.
This is the number that should be programmed into your BMV-702.
Lew Farber
Old 09-22-2016, 01:33 PM   #67
golfarch's Avatar
2007 27' Classic FB
I should reset to 180 ah?
"The Percolator"
Old 09-22-2016, 02:49 PM   #68
lewster's Avatar
You should determine the EXACT battery capacity listed on the battery label and multiply this number by 2 as your Group 27 batteries are 12VDC and the amp/hours of each battery is additive when connected in parallel.
Lew Farber
Old 10-01-2016, 12:42 PM   #69
golfarch's Avatar
2007 27' Classic FB
Installed new batteries and now getting two different readings at the battery terminals with converter charging; 14.01 left side 12.60 right side. I will monitor and see what happens as the day goes on.
"The Percolator"
Old 10-02-2016, 12:58 PM   #70
Rivet Slave
Rocinante's Avatar
Yikes! I'd check the connectors between your batteries for resistance to see whether something is awry.
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 01:56 PM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 01:34 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
