Old 09-11-2016, 02:33 PM   #43
2016 23' International
Salem , Oregon
I do not think you could do this as the blue tooth plugs into the monitor. You can do as Popou has done see pictures in earlier posts.
Also I did not want to cut hole and spent a long time searching and found the perfect location for mine and if you look hard I am sure there is a good location.
You would never know mine was not factory installed and looks very good, if I don't say so myself.
Dave
NoResults is offline   Reply With Quote
Old 09-12-2016, 06:07 AM   #44
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
BVM-700 Location
Originally Posted by Spinonedad View Post
I really don't want to cut a hole in my brand new 19 ft flying cloud
Can you order this unit with just the Bluetooth capability and not the display?
Take a look on the post #37. I take an aluminium 2x2 box and put it in the upper cabinet and secure it with Velcro
Michel
Papou is offline   Reply With Quote
Old 09-12-2016, 08:08 AM   #45
2016 19ft flying cloud
Spokane , Washington
How did you route the cable thru and out the Trailer without having to cut a hole in her ?
Spinonedad is offline   Reply With Quote
Old 09-12-2016, 01:51 PM   #46
2008 19' Safari SE
Brossard , Quebec
Cable routing bmv-700
The first hole: Is aside the water heater in transition over the storage external access compartmnet on curb side of the trailer. Not visible because it is located in the small area (less than 1.5 inche wide) between the bed frame and the closet)
The second one: At the upper corner of the same external storage compartment adjacent to the place where the electrical wiring is located under the bed. Not visible either. I put in this space the Victron's shunt.
The Victron's control cable was routed in the empty space between the trailer roof and the closet cabinet.
If you need pictures I can post themů
Michel
Old 09-12-2016, 01:57 PM   #47
Brav's Avatar
2016 25' International
Huntington Beach , California
Michel
I wouldn't mind pictures either.. Mine is all installed but still cant decide on the final mounting location of the 702
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Old 09-13-2016, 12:54 PM   #48
golfarch's Avatar
2007 27' Classic FB
Myrtle Beach , South Carolina
Originally Posted by Brav View Post
Yes, for now. But I plan to mount it just as Papou did in his pics - in the cabinet above the kitchen, in my case (up top, out of the way). If I get brave, I will cut a hole in the outside of the cabinet near the door. But I just use the app to check on everything before going to bed or after waking up, as I am in bed. I really do love the app.
I can even check on the MPPT and batteries while on the road, and can see the amps change in real time as the road curves relative to the sun.. Nice to see everything topping off on long trips as you go to your next destination.
I ordered the Bluetooth Smart Dongle today. Is it easy to install? Do you use the iPhone to download the app?
"The Percolator"
golfarch is offline   Reply With Quote
Old 09-13-2016, 01:01 PM   #49
Brav's Avatar
Plug the dongle into the back of the 702. Easy. Download the app on your phone from AppStore then turn it on. Will automatically search for devices. Then select your device. It will probably ask you to update the firmware. Then you will be good to go.
Attached is the app but for my MPPT
Old 09-13-2016, 01:11 PM   #50
golfarch's Avatar
2007 27' Classic FB
Originally Posted by lewster View Post
Yep. Sure does.
Lew Farber
Lew:
Do you make house calls?
Craig
"The Percolator"
Old 09-13-2016, 03:04 PM   #51
Brav's Avatar
Pic of app attached.. sorry
2010 LR RR S/C
Old 09-13-2016, 09:58 PM   #52
lewster's Avatar
Naples, FL , Hood River, OR
Lew:
Craig
Sorry....not any more!!! I have 2 installation locations instead, and they are in seasonally desirable locations: Hood River, OR in summer and Naples, FL in winter.
What's not to like???
Old 09-14-2016, 04:36 AM   #53
golfarch's Avatar
2007 27' Classic FB
When will you be in Florida?
"The Percolator"
Old 09-14-2016, 11:16 AM   #54
lewster's Avatar
Nov 1 thru April 30
Lew Farber
Old 09-14-2016, 02:40 PM   #55
Long Island , New York
New thread by OP FYI:
http://www.airforums.com/forums/f449...se-156894.html
Old 09-21-2016, 01:59 PM   #56
golfarch's Avatar
2007 27' Classic FB
Brav:
Where did you find the 'CODE' for the VE Direct to finish the iphone app installation? I can't find the 'CODE' anywhere. It appears to be numbers only?
"The Percolator"
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 01:56 PM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 01:34 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
