Old 08-30-2016, 12:21 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Since Victron's shunt contains an electronics board, they MUST be mounted in a water proof location, unlike the shunts that Blue Sky and Bogart Engineering use in their battery monitors which can be placed outside exposed to the elements.
Also, the temperature probe is bolted directly to a positive battery terminal and the 2 wires coming from it are connected into the appropriate ports located on the Victron shunt so it will read the true cell temperatures at that battery post. This data is visible on the BMV-702 remote, which is located anywhere inside your RV via the data cable.
Old 08-30-2016, 12:26 AM   #16
New Borockton , Alabama
Images: 21
Hey Lew, how does it measure direct cell temp mounted on the battery post? That would be interesting.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 08-30-2016, 11:00 AM   #17
2016 28' International
San Marcos , California
Temperature is measured using a Thermistor, see link:
https://en.wikipedia.org/wiki/Thermistor
basically as temperature changes so does resistance.
Although Victron's shunt needs to be out of the elements I think it has some other advantages, the temperature sensor connects to the shunt and the shunt is connected between the negative side and your load. Then you run a single commonly available ethernet cable back to your BMV-702.
Mgieselman is offline   Reply With Quote
Old 08-30-2016, 11:40 AM   #18
lewster's Avatar
Yep. Sure does.
Lew Farber
Old 08-30-2016, 12:55 PM   #19
2007 22' International CCD
Based on the size of the metal mass connected to the cell under the positive terminal, the temperature at the post should be close enough to the cell temperature. There's a lot of metal there.
KE4GNK/AE
Old 08-30-2016, 01:32 PM   #20
2016 23' International
Salem , Oregon
Victron Energy
Here is a link with picture of the temp sensor.
http://shop.pkys.com/Victron-Energy-...or_p_2812.html
Dave
NoResults is offline   Reply With Quote
Old 08-30-2016, 02:10 PM   #21
The battery temperature probe is a thermistor, basically as temperature changes so does resistance.
One advantage the Victron shunt has is it's a single common ethernet cable back to the BMV-702 since the temperature probe connects to the shunt.
Old 08-30-2016, 03:10 PM   #22
Brav's Avatar
2016 25' International
Huntington Beach , California
I also installed the 702 with bluetooth, and love it. Also have Victron MPPT with bluetooth, love it as well. I use the iphone app almost exclusively, have not hard mounted the 702 just yet.. can't decide on the final spot to cut a hole
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Old 08-30-2016, 09:43 PM   #23
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I ordered a victron mppt 100/50 with Bluetooth cable - looking forward to installing it....
Do you get that much more info from the 702 to justify the extra $200? I was thinking I could just live with the info from the mppt itself... But I can be upsold on adding a 702 monitor brings that more more value - let me know your thoughts....
wulfraat is offline   Reply With Quote
Old 08-30-2016, 11:35 PM   #24
lewster's Avatar
I would add the 702 and even go a step further with the new Color Control Monitor as well. They will give you more information that most can use, but it's great having information overload!
Old 08-31-2016, 08:26 AM   #25
Zil
egg harbor city , South Jersey
The power supply for the shunt electronics fasten to the positive battery with an inline fuse. Shouldn't the temperature probe fasten to the negative terminal? To avoid possible shorts.
Zil is offline   Reply With Quote
Old 08-31-2016, 10:41 AM   #26
Brav's Avatar
Yes, it gives you more relevant info. The MPPT will tell you total watts and amps generated, the 702 will tell you the net input/output of amp draw going in/out of the batteries. It will also give you amp hours consumed, and a much more accurate state of charge. You can also have bluetooth for it as well, reading both from your app. I havent even permanently mounted the 702 yet, I just use the app.
2010 LR RR S/C
Old 08-31-2016, 03:45 PM   #27
For the BM-702 it is connected inline to the negative side, the temperature sensor is connected to the positive side.
See the quick installation guide for details:
https://www.victronenergy.com/upload...0x_part1_2.pdf
Old 08-31-2016, 10:21 PM   #28
lewster's Avatar
Just to clarify:
The shunt is connected to the battery negative terminal with all negative loads attached to the other shunt terminal (there are 2 and they are marked) and the battery temperature sensor (BTS) for the 702 (it is for use in the 702 ONLY) is connected to the positive terminal. The 2 leads (red for positive and black for negative) coming from the BTS are inserted into the appropriate terminals on the shunt. The special BTS for the BMV-702 is purchased separately and is marked with a yellow label 'for use in 702 ONLY'.
Data is then transmitted to the BMV-702 via the data cable.
The Victron BTS differers from most others (Magnum, Blue Sky, Morningstar, Xantrex) in that it is connected to the positive battery terminal as opposed to the negative terminal that all the others use.
Victron also uses the ground side of the DC circuits as the control rather than the positive.
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 02:56 PM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 02:34 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-16-2016 12:03 AM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 03:20 PM
