Old 03-13-2018, 10:27 AM   #1
2017 27' Flying Cloud
London , Ontario
Victron 712 install in 27' FB
Hi all,
I recently got the Victron BMV-712 battery monitor. I had three questions, in the context of an install in a FC 27' FB (2017).
1) This model is Bluetooth-enabled. Does that mean that the monitor is completely superfluous and I can skip the install of that component?
2) I read the shunt is meant to be kept dry. Can I somehow do this install within the existing battery compartment, or does the shunt need to be on the interior of the Airstream?
3) If I elect to install the battery monitor itself, where would people recommend putting the monitor and how do people recommend threading the ethernet cable from the shunt to the monitor? I want to minimize drilling if possible.
Many thanks for any help from anyone with experience in this area!
Phil
Philip Jones is offline   Reply With Quote
Old 03-13-2018, 10:44 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
My understanding is that the Bluetooth transmitter is in the monitor housing. Mounting the monitor somewhere under something is the usual solution.
You *can* mount the shunt in the battery area. You will need a waterproof box to put it in. You will also need waterproof gaskets for the wire going into and out of the box. The most likely place to find room for the box is on the outside of the compartment (unless you have an unusually roomy battery compartment )
If both the shunt and the monitor go "under something" then the routing of the cable is pretty easy. Otherwise .... count on some fun. A lot depends on exactly where what items are on your trailer.
Old 03-13-2018, 02:17 PM   #3
London , Ontario
Thank you for the reply!
Does anyone know if a fit-for-purpose ready-made waterproof box is available from Amazon or other seller? Or, are people constructing their own?
Thanks.
Old 03-14-2018, 08:42 AM   #4
Half a Rivet Short
Thanks.
Hi
If there is one, nobody has ever found it. You need to fabricate something with mounts as well as the gaskets. Take a look at your battery box. My guess is that there isn't any room inside. If it's external, you need to fabricate something that will survive a rock strike ....
This (or another one in the product line) isn't a bad starting point:
https://www.digikey.com/product-deta...M576-ND/284773
You still need a gasket for the box and the watertight fittings for the wire in and out. I don't have a box or a shunt handy so I'm only guessing at the size. It's aluminum so you can paint it with normal primer and paint.
Old 03-14-2018, 10:11 AM   #5
2018 27' Flying Cloud
Atlanta , Georgia
I bought a Victron 700 and am planning an installation as well. My thought is to put the shunt inside the rear storage area (on the driver side) where the solar and inverter are located. I will have to get some battery cables to make it work and have not figured out all the details yet. While I also bought the Bluetooth, I am thinking of putting the display in the bedroom area inside one of the upper storage cabinets.
jnm30327 is offline   Reply With Quote
Old 03-14-2018, 10:12 AM   #6
rogerdog1's Avatar
2013 25' FB International
Littleton , Colorado
I have seen a WP box for it. Just search Victron or Amazon. When you wire to it, use welding cable, as it is very flexible, so you can use the same gauge cable as is going to your batteries now. Again, lots of choices on Amazon.
rogerdog1 is offline   Reply With Quote
Old 03-14-2018, 03:49 PM   #7
Parker , williamdcrockett
Hi all,
Phil
I have a 2012 27FB. I installed a Victron BMV 700 shunt and monitor / display in a custom made pine box. I mounted the box by the power terminals under the bed in the front storage bin. I also have the Bluetooth Dongle so I use the iPhone app to control everything. The app does everything that the controls on the display do so I do not need to look at the display in the storage bin.
wcrockett is offline   Reply With Quote
Old 03-14-2018, 09:52 PM   #8
London , Ontario
Thanks to all for the information! Very helpful.
Old 03-15-2018, 07:39 AM   #9
Fort Worth , Texas
Look at PKYS for waterproof solutions if you want to place your shunt in the battery box. I placed mine (712 model with bluetooth) in the storage compartment of my 27 FC (FB) and that has worked well.
billrector is offline   Reply With Quote
Old 03-15-2018, 03:16 PM   #10
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
Box for bmv-700
Hi all,
Phil
I install the BMV in a small die cast aluminium (patiently polish) box.
Hold in place by a velcro tape near the Sony receiver/DVD player.
The shunt is located at front of the trailer (23FB).
Cable is routed inside at the top of the "roof locker" dinette curb side.
If you need additional pictures, I can post.
Michel
ID:	306390   Click image for larger version
ID:	306392   Click image for larger version
Papou is offline   Reply With Quote
Old 03-15-2018, 03:29 PM   #11
2016 19ft flying cloud
Spokane , Washington
How did you get that cable thru that small opening and where does it come out?
Spinonedad is offline   Reply With Quote
Old 03-15-2018, 05:14 PM   #12
London , Ontario
Thank you to everyone for the very useful advice! Much appreciated.
Old 03-15-2018, 05:26 PM   #13
2007 22' International CCD
Nicely done!
Old 03-15-2018, 06:31 PM   #14
Fort Worth , Texas
Just a reminder, with the bluetooth, you can locate the meter anywhere. I have mine located in the front locker above the light. Not easy to see, but far more information available through the app and the bluetooth connection anyway! May not be worth a lot of work just to locate that meter in a spot that is easy to see!
Victron BMV702 Install BoscoMN Electrical - Systems, Generators, Batteries & Solar 63 04-06-2018 07:55 AM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 01:24 AM
Victron Battery Monitor Install NoResults Batteries, Univolts, Converters & Inverters 82 01-23-2017 11:02 AM
Victron BMV 702 install using solar prewire Brav Batteries, Univolts, Converters & Inverters 4 11-21-2016 02:22 AM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-16-2016 12:03 AM
