Originally Posted by 65CV
Overcharged lead acid batteries produce hydrogen gas, which is obviously explosive if not properly vented. Hydrogen gas will rise -- that is why the battery compartments are vented up top.
I'm curious. How did you learn that your Lifeline produces gas? I thought they were well sealed.
John
I was told they shouldn't unless the case is compromised.
Hope it's true!! "designed to reduce outgassing under normal charging conditions"
They are in the Classic compartments, kind'a tight in there and smallish vents 'ta boot.
