Old 06-25-2019, 10:14 PM   #1
pt.reyesfan's Avatar
2016 30' Classic
Naperville , Illinois
Using refrigerator on 110 trips my Main GFI breaker
What is going on here? Advice? (I have a 2016 Classic.)
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
pt.reyesfan is offline   Reply With Quote
Old 06-25-2019, 11:16 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If you're talking about a GFI breaker on your residential porch or garage trailers can be weird that way, if you're talking about a GFI in your trailer, your fridge may have a ground fault.
Old 06-26-2019, 10:26 AM   #3
2016 30' Classic
How do I determine and fix that?
Ed
Old 06-26-2019, 10:44 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Before you blame this on the fridge, I'd point out that the Siemens GFCI breaker in recent Airstreams is somewhat notorious for becoming unreliable. (I'm assuming the Classic uses the same breaker as my '17 Flying Cloud.)
I started to have the GFCI breaker open at random inconvenient times and worked down to the point where only the fridge was plugged in and it kept happening. Then I unplugged the fridge AND IT CONTINUED TO HAPPEN. I replaced that Siemens breaker with another $40ish Siemens GFCI breaker and the problem hasn't recurred in many nights of camping since then.
It is possible for the heating element in the fridge to have a ground-fault. It's also possible that your Siemens GFCI breaker is junk, and it's much cheaper/easier to replace!
— David
Old 06-27-2019, 10:30 AM   #5
2016 30' Classic
I replaced the breaker. Success!!!! Thanks!
Ed
GFI breaker trips when on shore power Wrpooley 2016 - Current International 11 09-13-2018 07:24 AM
HELP - GFI Breaker trips T Reno General Repair Forum 4 11-02-2017 12:47 PM
DAMN GFI Breaker dan50w Lights - Interior & Exterior 13 12-24-2009 12:59 PM
Lifespan of GFI breaker? blickcd Lights - Interior & Exterior 7 07-07-2009 11:23 AM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
