Old 09-12-2017, 09:26 PM   #1
FCStreamer's Avatar
2014 30' Flying Cloud
Using external charger?
I was wondering - would I be able to use an external charger like one of these
https://no.co/products/charging/multipurpose
To keep my batteries charged?
My use case - my trailer is "stored" in an RV park and is plugged in 24x7. I don't do many trips. I use it every weekend though. So I keep the Use/Store button in the Store position during the week, and set it to Use on weekends.
I'm thinking I can leave that button in Store position permanently and connect an external charger. I'm not sure if I have to disconnect the batteries from the trailer before I do this. Do I?
Please don't go down the "upgrade the OEM converter/charger" path. It's a long story, so let's just say that's not an option right now.
I'm curious if I can just clamp on an external charger to the batteries as they are or do I need to disconnect them from the trailer first. Any guidance will be appreciated.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 09-12-2017, 09:33 PM   #2
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Go ahead and use an external charger, I have had no problems with mine. Mine is a Batteryminder 1.5 amp that does a great job of keeping the batteries topped off. If heavy charging is needed use shore power for a few hours then let the charger top them off and maintain them.
Mattirs is online now   Reply With Quote
Old 09-12-2017, 09:44 PM   #3
FCStreamer's Avatar
Do you leave your batteries connected to the trailer while using your battery minder?
Old 09-12-2017, 10:49 PM   #4
2015 30' Classic
Pleasanton , California
This charger should be fine.
Simply connect the external charger directly to the battery terminals. You won't do any harm if the use/store switch happens to be in the "use" position, but your batteries will be better served if you double check and make sure you've selected the "store" position.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 09-13-2017, 01:24 AM   #5
Mattirs's Avatar
Yes I do. Actually installed a ring connection with a quick connect to the battery.
This way I can disconnect/ comnect swiftly as needed
Old 09-13-2017, 05:11 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The store/use switch disconnects the batteries from the trailer except for the propane detector and the tongue jack.
The detector is the problem. It runs the batteries down in just a bit.
Turn switch to store, this will prevent the stock convertor from overcharging and use an automatic automotive charger. No need to remove the main battery cables.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-13-2017, 05:50 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That's what I do too. I leave the trailer unplugged and also installed a quick connect directly to the batteries.
2012 Dodge Durango Hemi/AWD
Old 09-13-2017, 06:08 AM   #8
FCStreamer's Avatar
That sounds great! Now, for the charger, I've read many good things about BatteryMinder, but I'm partial to Noco products. I own a couple of their jump starters. I'm thinking this one is the correct one
https://no.co/g3500
Says $80 msrp but it can be bought for around $60. Cheaper is good. They also sell all sorts of quick connect and extension cables.
This one seems better
https://no.co/g7200
With higher amps but costs more (around $100) and seems overkill.
For my specific use case, I'm leaning towards the 3500. Thoughts?
Old 09-13-2017, 07:57 AM   #9
jdalrymple's Avatar
Jay , Oklahoma
No need for a high amp charger.
IF the requirement is to simply prevent the batteries from draining during storage, one only needs to provide slightly more amperage than the propane detector draws.
An amp or two will be plenty.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 09-13-2017, 09:14 AM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You want to avoid the high current "jump start" and "fast charger" models (at least some brands of them) for this kind of thing. Some of them do wacky things when left on full time. Anything that is designed as a "maintainer" sort of device should be adequate.
Old 09-13-2017, 01:02 PM   #11
2017 27' International
Fall City , Washington
I use the Battery Minder that has a 2, 4, and 8 amp setting, desulfation mode, and supports 2 batteries of the same spec.
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 09-13-2017, 02:22 PM   #12
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
I'm going to use the same over the winter. Does anyone see a need to pull the batteries to inside the house?
That would difficult for me since I barely got these two group 31's wedges in the box and had to modify the lip of the battery box to accomplish this
dmbecke is offline   Reply With Quote
Old 09-13-2017, 02:36 PM   #13
Wayne&Sam's Avatar
Images: 21
Me too.
Old 09-13-2017, 05:04 PM   #14
Mattirs's Avatar
It all comes down to how fast do you want to recharge the batteries, and then how does the charger maintain the batteries after they are charged. More amps means a faster recharge, but is there a need for a fast charge while the trailer setting at home?
Then once the batteries are charged will the charger groom and maintain them properly. Both brands according to specs do so.
There is a website (Northwestbatteryschool?) that is very educational. It will help you decide. Knowledge is power.
(hard to type on ones phone while riding the bus)
Matti
Should I charge batteries with external battery charger Mattirs Boondocking 12 01-10-2017 02:58 PM
Anybody Using External/Outside Stereo Speakers w/ Your Airstream? How? 66coupe Audio, Video & TV 2 06-22-2015 03:11 PM
external charger effect on electronics thebreezeman Electrical - Systems, Generators, Batteries & Solar 2 02-05-2015 07:37 AM
External charger and battery ? Rousseau Batteries, Univolts, Converters & Inverters 5 09-01-2011 12:55 AM
Black water holding tank changes for using trailer as stationary home/external septic bol-gordon All Argosy Trailers 3 05-20-2009 07:34 AM
