10-30-2015, 10:43 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Upgrading to 6V Trojans - Series Parallel Wiring - Battery bank build
The time has come for this project. The plan; upgrade my existing two group 27 batteries to four 6v-Trojan AGM's wired in series parallel to create two big 12v battery banks.
This is how I intend to wire the batteries together:
I'll be moving my batteries from the tongue to the back of the front storage compartment. I might move them elsewhere within the bedroom based on feedback to this post.
For those who don't recall, our bedroom is a little different than the standard queen or twin. The front storage compartment also gained a few inches in depth.
And maybe I can get a few things sorted with your help.
I have read recommendations to use 4/0 class 'K' welding cable between the batteries. As I understand it, the Airstream's current direct connections to the main panel are 6 gauge. Curious if anyone thinks I should upgrade this to 2/0 or 1/0 gauge.
Currently, present between the battery and the Airstream is a 50-amp fuse breaker. Should I consider upgrading this to 80 or 100-amp?
I'll document the rest of this process in this thread as I make progress on the work. This week we are acquiring out batters and cables. And should be getting started next weekend.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
10-30-2015, 10:52 AM
2016 25' Flying Cloud
Venice
I have 4 trojans in my golf cart & they are awesome, good luck with your project.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
10-30-2015, 11:31 AM
Naples
Bold,
Since the series/parallel connections are essentially a continuation of the internal battery plate connections, I would go 4/0 for those.
I usually use 4AWG or 2AWG ( depending on run length) for the connections from the batteries to the bus bars. 50 amps for circuit protection is fine.
If you have an inverter. I would upgrade the direct connections for the battery to inverter with 1/0 ( again length dependent) using a 150 amp class T fuse.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
10-30-2015, 12:29 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Bigger, cleanly terminated is better!
10-31-2015, 09:14 AM
Curtis Wright
Eyren Haven
, South Jersey
I recommend you use marine cable rather than welding cable. You can even get it made to order with proper connectors. Such as 1 of many= Custom Battery Cable Assembly Custom Made Genuinedealz.com
10-31-2015, 10:19 AM
Nomadic
, USA
Thanks. I'm a huge fan of cutting and crimping my own wires so I only have myself to blame for most things. I'm leery of marine as I've purchased some before that were copper coated tin.
10-31-2015, 10:35 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Belden welding wire is the best bang for the buck. It is very high quality, fine stranded wire in a very durable neoprene/PVC jacket. It solders beautifully!
10-31-2015, 10:51 AM
1989 32' Excella
Sharon Springs
, New York
Interested in doing such an upgrade next Spring ourselves, how much weight is added by using 4-6Vs vs. the code 27 batteries? We have 2-12V code 24s in the factory compartments one on each side of the A-frame in the body of the trailer, assuming its for even weight distribution, are you mounting them the same way? Sorry we can't add more towards your decision making process but will follow your thread and use it to plan our upgrade. Good luck and thanks for the idea...
Regards,
James and Rebecca
10-31-2015, 11:26 AM
2004 25' Safari
1999 27' Safari
1968 17' Caravel
Fountain Valley
We did a similar project almost a year ago, only on a slightly smaller scale. Our 25' Airstream had two size 24 batteries and I switched them to two Trojan 6-volts. Increased capacity from approx. 80 AH per battery to approx 225 AH per battery (now 450 AH total instead of 160 AH total). What an incredible difference as we have solar and do mostly dry camping.
Cable size will be determined in part by how large of an inverter you will be using. We do not use our inverter for the microwave or electric coffee pot, so extra large wiring not an issue. The wire we used earlier for the inverter wiring was MARINE wire.
BATTERY CONVERSION NOTES:
Converted from (2) 24-sized batteries to (2) 6-volt golf cart batteries ((2) Trojan T-105 Batteries 2*($125-$10pickup+$20core)+$21.60 tax).
Items:
1. Replace the 3/8" threaded rod (I think I went from an 8" to a 10", or a 10" to a 12", can't quite remember). Rod replacement is not easy because it is threaded through a nut which is welded on the outside bottom of the battery box, and then the rod is seal welded to the nut. You have to grind off about half of the nut in order to be able to unscrew the existing rod. (With the "undercoating" on the bottom of the battery box this was not evident, so thinking that you could unscrew the existing rod took a lot of time. I called the AS factory and the technicians went out on the floor to examine the bottom of the battery box, but still didn't know that the rod was welded. You cannot use a 3/8" rod coupler to extend the rod, as there is insufficient room for the larger gap required between batteries.
2. The size 24 batteries sit in a plastic shell at the bottom of the battery box. My local AS dealer just removes it and leaves it out, if they do the conversion. For me, I removed it, then cut out both ends of the plastic shell so that the golf batteries would sit on plastic in the bottom of the box.
3. The battery box has to be heightened. This was not a problem for my AS, but if someone has a forward storage outside door, they would have to have the box extended down, instead of up as I did it. I had some 1"X3" oak, so i just made a 2 1/2" extension on the top of the box, and moved the lid up, and it was fine. (Our local AS dealer can fabricate a 2" or 2-1/2" box extension, but opted to make my own.)
4. The two new 6-volt batteries have to be wired in series, instead of in parallel as the 12-volt batteries were.
5. I had to use a pneumatic "nibbling" tool to enlarge the propane tank cover cutout to fit the taller battery box (i.e. trim away 2 1/2" of aluminum to make the propane tank cover slip over the two propane tanks and fit properly)
6. The golf cart batteries don't use automotive type posts, so I had to cut off the ends of the battery cables, buy a heavy lug crimper (on ebay about $25), and crimp on some lugs to fit the new battery studs.
Notes: I didn't re-weld the battery hold-down rod, I just used lock nuts on the bottom outside. Also, I took advantage of having the batteries removed and scraped the corrosion out and reprimed and painted the inside of the battery box.
10-31-2015, 12:45 PM
1974 25' Tradewind
Calgary
, Alberta
If your Trojan 6-volts are rated at 225 AH each, you now have 225 AH at 12V total, not 450. If you programmed your chargers based on the 450 AH number (and/or if you do discharge percentage calculations based on that number) you are overestimating by a factor of two.
10-31-2015, 12:51 PM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Items:
I'm interested in performing a similar upgrade and have been reviewing data sheets for flooded lead-acid as well as AGM batteries. I'm looking forward to following along with BoldAdventure when pictures and descriptions are posted. I will likely use AGM as I plan to install the batteries inside the trailer, under the couch. I'm familiar with putting two 6V batteries in series to obtain 12 V and hope to put two banks of series batteries in parallel to double the available capacity.
So... I'm not following your math. Trojan flooded lead-acid, T-105, 6V batteries are rated at 225 Ah (the 20 hour rate). Putting them in series doubles the voltage to 12V, but does not double the capacity. Putting batteries in parallel doubles the capacity. Please explain - perhaps I've overlooked something.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
10-31-2015, 02:26 PM
2002 25' Classic
Kalama
You'll like it
We did this project a dozen yrs ago to store what our solar panels generate. The details today are a bit fuzzy but we used the existing compartments (after enlarging and taller doors) and built an inside chase for two batteries under the forward couch (sealed to inside/vented outside). This arrangement allowed short cables but made tongue weight a concern. As I recall, I calculated, then measured a new tongue weight w/in 60lbs. of max (and knew that I could further reduce by packing items aft of the axles). Battery maintenance is a bit of a pain, but doable… certainly worth the added performance if dry camping is a goal.
And yes, doubling 6 to get 12v does not double the amps. But two banks of 6v pairs that are paralleled does.
10-31-2015, 04:51 PM
Nomadic
, USA
No you actually have 225 Ah
You're on the right track, this is why I am wiring series parallel.
Series adds the voltage of the two batteries, but keeps the same amperage rating (also known as Amp Hours).
Parallel connections will increase your current rating, but the voltage will stay the same.
If you have two sets of batteries already connected in parallel, you can join them together to form a series.
You can learn more here: Trojan Battery Company
10-31-2015, 05:50 PM
2007 16' International CCD
Somewhere
True that two 6V batteries in series does not double the amp hours.
But, two 6V golf kart batteries in series have about 225 amp hours, which is significantly more than the 160 amp hours available from typical 12V batteries wired in parallel.
For this reason alone it is an upgrade worth considering. We did it, and are very glad to have the extra in reserve.
10-31-2015, 06:00 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
Two Lifeline GPL-6CT AGM batteries will give you 300 a.h. for the same footprint as the Trojans.
10-31-2015, 06:04 PM
Nomadic
, USA
And a 40% difference in price too.
And the problem I ran into here, is I called around to see if anyone had Lifeline's. And no one does. Nearest place is in Oregon and CA. Freight charges for 4 of them were $225.00. So if someone knows where I can get those without the freight charges. Seems I can order them online, but not get them in person.
10-31-2015, 07:05 PM
Naples
Bold,
PM me, I think I have a solution for you. :-))
Lew Farber
541-490-6357
lewster
10-31-2015, 07:14 PM
1974 25' Tradewind
Calgary
, Alberta
We are FAR from having to think about batteries but because our '74 Trade Wind has the battery compartment behind the curb-side axles, I'm thinking of the Trojan T-1275 as a useful upgrade to the run-of-the-mill 80 AH deep-cycle battery.
The T-1275 is spec'ed at 150 AH and only marginally larger than the 80Ah battery. I just need to see how much surgery will be required on the battery compartment.
11-01-2015, 01:16 AM
2004 25' Safari
1999 27' Safari
1968 17' Caravel
Fountain Valley
Corrections for Inaccurate Amp-Hr Information
I've had several folks advise me relative to my improper AH information in my Quote below.
I stated that with two 6-volt 225 AH batteries I now have 450 AH total, but the correction is that for two 6-volt batteries in series we wind up with a 12-volt system with a 225 AH capacity instead of the 450 AH I thought we had.
That being said, there is a noticeable, substantial improvement with the Trojan batteries over my previous system. I am advised by the battery supplier that the Trojans also have greater longevity than what I was getting out of the previous 12-volt deep-cycle batteries.
Items:
11-01-2015, 01:39 AM
2015 27' Flying Cloud
2011 30' International
mooresburg
, Tennessee
has anyone tried the 6v interstate batteries?
