Old 12-14-2015, 05:23 PM   #43
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
No pic bold!
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 12-14-2015, 06:18 PM   #44
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by Buck944 View Post
No pic bold!
Yeah, I can see them, but not when I'm logged out from Google, and it seems I can't find the option to make them public anymore. Guess I need a new hosting method.
So here is served from others sources
I'm working on the full write up, but it might need to be multiple posts. At 4000 words now. And just a rough draft. Look I already see a typo.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-14-2015, 06:36 PM   #45
2015 30' Classic
Pleasanton , California
Bold, looks very good. What's with cell #4?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-14-2015, 08:08 PM   #46
Nomadic , USA
So that cell is right next to the charge controller, which I noticed puts off a lot of heat when doing it's thing. Doesn't seem to be doing it today now that they are all balanced, but yesterday it was the one cell with a higher temp than the rest. Certainly an odd occurrence.
Old 12-14-2015, 08:17 PM   #47
2015 30' Classic
Maybe an insulating blanket around the entire pack could shield #4 and keep them all at the same temperature?
Al, K6IV
Old 02-06-2016, 07:52 PM   #48
Nomadic , USA
Thumbs up
Eventually I finished everything. We have been lithium powered since mid-December. And all is well. The lithium's are great. A wonderful investment. We've got all the power we could ever want.
If you're curious, here is how I ended up laying out my system. I probably won't post a detailed DIY thread on this forum, mostly because I don't want to endlessly debate the merits of my system.
We now have 400 amp hours of battery, with 505 watts of roof solar which will be complimented very soon by 300 watts of ground deploy solar for a total of 805 watts.
Old 02-06-2016, 09:12 PM   #49
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Nice!!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 02-06-2016, 10:44 PM   #50
Bold venture could you post a picture of the 500 W solar on the roof of your airstream I'd like to see how there laid out.
Thank you.
n9hox is offline   Reply With Quote
Old 02-07-2016, 08:50 AM   #51
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Here is how we installed five GS-100 hundred watt solar panels on the roof of our 2015 23D. There are two in front of the air conditioner and three behind the air conditioner with one of the three mounted cross frame while the other four are in line with the frame.
We also replaced some stock Airstream roof parts with a Maxim skylight, two Maxxfan 7000K roof fans and a WineGard Rayzar automatic television antenna.
Name:	23D five solar panels.jpg
Old 02-07-2016, 09:08 AM   #52
Nomadic , USA
I just realized my drawing is wrong. Sigh. Spent an hour drawing that. The leads into the controller from the solar are drawn wrong. Pos and Neg from the combiner goes into the controller, then from the controller pos and neg back to the batteries/shunt.
Thank you.
You can see my layout here:
I have three of the 135 watt panels, and one of the 100 watt panels. I have been thinking of rearranging these, but why bother. I have room for another 100 watt panel on the roof on the street side.
batteries, inverter, parallel, series, solar, trojan
Solar panels in series or parallel - but why not both? drboyd Generators & Solar Power 19 10-16-2017 08:39 PM
Series Parallel Battery Wiring - Which is correct? trekerboy Electrical - Systems, Generators, Batteries & Solar 22 01-01-2015 08:52 PM
Battery hook up, parallel or series iamscuba2 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-15-2011 09:33 AM
Parallel not-alike honda eu series generators malimish Generators & Solar Power 26 02-04-2009 10:26 PM
Series or parallel benwd Batteries, Univolts, Converters & Inverters 52 11-03-2007 08:19 PM
