Old 09-19-2014, 12:35 PM   #29
Tincampers's Avatar
Sneedville , Tennessee
Originally Posted by Moflash View Post
Got tired of ruining my batteries and called Randy at Best Converters.Installed the Ultra III unit in approx 20mins ($220) threw Parallex in dumpster and installed new Lifeline group 27's($500).Replaced every light in my trailer with LED's fromled4rv.com($600).
Best upgrade so far.Just returned from a 45 day 8,000 mile adventure and could not be happier.Huge difference in charging quality, performance power usage.One of the best upgrades I have done.
Did that require a modification to your battery box?
Tincampers is offline   Reply With Quote
Old 09-19-2014, 12:45 PM   #30
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Yes,took 10min with a 6 inch grinder and 10 mins to paint area I ground on.All you do is remove about a 1/2 inch of the rear lip on the box surround and leave a 3 inch strip in the middle alone for the battery lock arm to function.I also installed longer positive and negative cables for the jump cables only as the factory main cables are fine for the close battery.
Structural integrity is not compromised (for those naysayers on the forum).
I got the longer jump cables at Bass Pro shops.
Old 09-19-2014, 01:17 PM   #31
lewster's Avatar
Naples, FL , Hood River, OR
TECH TIP!
You will find it to be more pleasing (and easier to do) if you remove the rivets from the top cover and cut away that 1/2" from the flat front lip. Re-paint, re-rivet the cover and it is invisible.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-19-2014, 01:21 PM   #32
lewster's Avatar
Originally Posted by PharmGeek View Post
I re read the thread and foggy on the difference of magnum vs this PD model
Easier less costly install it seems?
I will have only a generator probably for a while at this point (pick it up tomorrow yay) as it relates
I have stock 1000w inverter and would not require it much at all for the next few years I suspect but a bit later more so
Depends on what batteries you have and how long you want them to last. The Magnum has one of the best charging sections available. Also has full temperature compensation and is programmable for battery type and the size of your battery bank. These features are not available on converters.
Lew Farber
541-490-6357
Old 09-19-2014, 01:27 PM   #33
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by lewster View Post
TECH TIP!
Lew Farber
541-490-6357
Great info Lew.
I had solar and AGMs installed last week at AM Solar. They were out of Inteli-Power 4645s.
I'd like to find someone in my area to do the install. What credentials should they have to do this job and how much labor is involved?
I'm always cautious about having the A/S dealer do almost anything despite the fact that they say "sure, we can do that".
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-19-2014, 01:54 PM   #34
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Thanks for the info
What is ballpark labor cost for the magnum install + new lifeline agm batteries including slight box modifications ?
My hope is that I will just drag along ok with all my current stuff for 3 years then I can get a bit of solar and the converter/inverter and a battery upgrade.
How can I for now with my current equipment do the best I can to keep batteries healthy as is?
Obviously not leaving in "use" battery mode and keep batteries topped off with my battery tender I have now (although I am unsure of it's quality
PharmGeek is offline   Reply With Quote
Old 09-19-2014, 02:22 PM   #35
lewster's Avatar
Originally Posted by interstateflyer View Post
Great info Lew.
It's not a big job....... Just removing and replacing the AC and fuse wiring from the P/lax to the new PD. Usually takes me under an hour.
Try to find a Certified RV tech in your area with a lot of electrical experience.
Lew Farber
541-490-6357
Old 09-19-2014, 02:23 PM   #36
lewster's Avatar
Thanks for the info
Geek,
PM me for details.
Lew Farber
541-490-6357
Old 02-20-2015, 05:44 AM   #37
2012 27' FB International
Victor , New York
Mhg nm , . ,because ,like l
L il blip. K .m 11
Meddle is offline   Reply With Quote
Old 02-20-2015, 11:23 AM   #38
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Might want to fix that I-Pad....
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 02-20-2015, 12:03 PM   #39
Victor , New York
Sorry about that everyone...my 1 year old (tomorrow) got ahold of my iPad. Yes, she can slide to unlock it!
Old 02-20-2015, 12:11 PM   #40
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
> new Airstreams have all LED lighting ....
not the Sports I understand.
I see the need for the inverter and an efficient one at that.
If these AGM batteries, particularly the Lifelines really are super super robust, then is it necessary or worthwhile to go through the trouble of replacing the converter/charger with something non-standard ?
timhortons is offline   Reply With Quote
Old 02-22-2015, 03:14 PM   #41
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Yes, it is. If you are going to spend the money on a high quality AGM (Lifeline), you don't want to destroy them with a battery charger that's stupid. The really high quality units will allow you to customize them for the type of battery they're charging....i.e., how much time does the battery need for absorption, float, equalization or whatever applies to your battery type. Otherwise, just buy Interstate's.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-16-2017, 08:15 PM   #42
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
So I know from PM with Rocinante that the pendant that can be ordered with the PD4655 wasn't ordered or installed. If anyone has done so with a 27FB - could you post pics of your installation specifically of the pendant and describe where in the process you installed it? I may go without as apparently you just open the panel and get a visual cue with LEDs which would be simple enough. I'm just curious if anyone has done it. Thanks!
SteveSueMac is online now   Reply With Quote
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Mixed batteries and surprised with converter/inverter outofcontrol Batteries, Univolts, Converters & Inverters 14 05-08-2014 09:04 PM
Trying to find the inverter and converter janeinthemtns Electrical - Systems, Generators, Batteries & Solar 5 07-22-2013 01:26 PM
Upgrading converter in 2009 19' International 50KIP Electrical - Systems, Generators, Batteries & Solar 5 07-28-2012 03:46 PM
Upgrading converter due to fan noise Jammer Batteries, Univolts, Converters & Inverters 20 07-05-2011 11:04 AM
