Couldn't get post to update again so here is my wiring plan and questions.
So the left most panel is all tow vehicle wiring a b c d and will be wired into x y z aa using inline fuses. That seems straight forward.
E is the power on light that was my boy for the university vol so that will be discarded.
The middle school panel f g h I k and any new lines I need will be wired into the terminals on the new panel. Again fairly straightforward.
Now getting to where I start to have some uncertainty the right side of the panel.
M battery positive will go to 1 of the 3 big dc Inputs on the new panel. Does this need an inline fuse between the battery and panel? If so how do I replicate the connection with s ( jack/hoist) and t (main 22 v charge)which have their own 20 and 30 amp boxes/fuse? Does T go to the dc input terminal?
All the white ground wires under U will be wired to the ground bus terminals on the new panel. Negative battery and converter lines and whatever tow and dc output negatives I may have
Positive converter line goes into large dc input terminal. Do I use an in line fuse on it as well?
Finally, I think, what about the ammeter lines? Now I'm using the original control panel but am replacing it with a seelevel tank monitor system model 709-ph. Do I need these ammeter lines or not? If not does the monitor measure the battery voltage through its dc power line coming from a new line on the parallax panel?
Any help would be greatly appreciated. Thanks in advance.
