Old 07-05-2011, 11:04 AM   #21
Wise Elder
Jammer's Avatar
2010 30' Classic
While the topic is controversial, some who question the safety benefit of the LP gas detector disconnect or remove them rather than installing a switch. They typically draw around 100 mA.
The breakaway switch should not draw power unless there is dirt bridging the contacts, in which case the simplest thing might be to just replace it.
Also, phantom draw is possible from the umbilical connector, if it gets dirty and wet, as may happen during storage.
Converter fan noise - parallax vs others Jammer Batteries, Univolts, Converters & Inverters 4 05-11-2010 07:59 PM
Motor / fan noise realpank Argosy Motorhomes 4 02-06-2010 08:56 AM
NT-22A Fan Noise mandonaut Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-26-2009 06:24 PM
Fan noise flyguy 2005 and newer - Bambi all models 2 07-29-2007 12:00 AM
Fantastic fan noise oxblood Roof Vents, Skylights & Fans 5 03-16-2005 12:28 PM
