Old 08-21-2006, 03:05 AM   #1
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
Upgrading batteries in a 2005 bambi CCD
I currently have 2 SRM group 24 batteries on my rig. I will need to be replacing these soon.
Has any one put group 27 or 27T batteries in the battery box? I am not sure there is room. But if any one has put in 2 larger capacity batteries I would be interested.
JDL
JDL is offline   Reply With Quote
Old 08-26-2006, 12:39 PM   #2
JDL
JDL's Avatar
T , Oregon
Hmm. I was hoping at least one person... had upgraded their batteries from the group 24 size on a 19' bambi .. ... Anyone?
Old 08-26-2006, 12:54 PM   #3
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
JDL.
I don't have an answer for you, but I do wonder why you are replacing the current set so soon? Are they bad already? If so they should definately be under warrenty. Are those the Interstate batteries?
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-26-2006, 02:32 PM   #4
JDL
JDL's Avatar
T , Oregon
Jonathan,
Thanks for responding. The previous owner discharged the batteries completely. (Dead.... Dead Dead...) I have them charged back up. But they are only at about 75% of capacity.. So, they work - but not well and I know enough about batteries to know they will not last too much longer.
JDL
Old 08-26-2006, 05:57 PM   #5
2005 16' International CCD
Ogden , Utah
JDL:
I have 1 2005 CCD, but a 16' with a single group 24 battery. There are a couple of things I found out for going to a group 27 that might be useful to you.
First of course is the size of the battery - an inch and a half longer
Group 24 = 11 1/4 X 6 3/4 X 9 1/4
Group 27 = 12 3/4 X 6 3/4 X 9 1/4
Next is the weight - probably not a big deal, but you'd add about 10#
Group 24 = 48#
Group 27 =53#
Also, I found that the battery cables did not have enough 'reach' to get to the terminals. I suspect they were wired from the battery back into the trailer, and there was not enough slack to reach. Cables can be replaced with longer ones, but it's a pain digging out the sealant used to seal the opening where they go into the trailer.
These numbers are from a general reference, and I don't know if you might find differences between brands. Let me know what you find out - I think Airstream builds these with little room for upgrading to a larger size.
Hope this is helpful
RDM16CCD is offline   Reply With Quote
Old 08-26-2006, 06:11 PM   #6
Kintscher's Avatar
Eugene , Oregon
We have a 19" 2005 CCD also and were having problems keeping the batteries fully charged. We took it to the dealer (Sutton in Eugene) and they said one of the cells was bad and replaced both batteries.
JDL, did we meet you at Beverly beach last year? If so, glad to see you found a trailer!
Kintscher is offline   Reply With Quote
Old 08-26-2006, 09:19 PM   #7
Darrell Root's Avatar
2004 28' International CCD
Camarillo , California
Link
JDL, I was needing new batts. on my 28' CCD it seems the box is large enough, but I have not checked cable length. I had the misfortune of grabbing a bottle of reg. water to top off the cells. I'll go with grp.27 if cables reach. Darrell
Darrell Root is offline   Reply With Quote
Old 08-27-2006, 12:50 AM   #8
JDL
JDL's Avatar
T , Oregon
Thanks to all who replied.
Brad,
Yes, you probably did as I came by and was the guy looking for a CCD. Thanks
RDM16CCD - Good. Info based upon your measurements and Darrell Roots box observations I will see what I get. I also need to check cable length. But if its only 1 inch and 1/2.... It should be ok..
Old 08-27-2006, 09:00 AM   #9
2006 30' Classic
Farmington , New Mexico
Images: 14
Brad,
JDL--We had a ccd16 2004 and replaced our 24 with a group 27. Cable length is a concideration . I was able to work enough slack in the cables to use it without breaking the sealant in the foor. Suppose it just depends on the individual trailer. The added capacity,[24 to 27], made a big difference in our boondocking ability.---pieman
Mike Lewis is offline   Reply With Quote
Old 09-06-2006, 07:33 AM   #10
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
store/use switch and charging?
This should probably be a new thread but...
When not using the trailer and stored in the driveway, I normally keep the store/use switch in the store position and keep an external charger hooked directly to the batts. and check the water regularly.
Now after almost 4 years, the batteries are slowly losing their mojo and I figure I'll be replacing both next spring (I've started using a Battery-Minder attached directly to the batts this summer and they have held up as well as can be expected).
What I discovered yesterday surprised me though...
I was breaking in the new Honda eu3000is (what a beauty! and quiet, my god!) and thought I'd put a mild load on it for a few hours so I plugged in the trailer. I turned on the A/C fan and both Fantastic Fans figuring that'd put a few watts of load on it. That went along for six hours nicely and the voltage meter in the trailer read a rock-solid 123v all day.
When I shut down the generator and started putting everything away, I went into the trailer and turned on an overhead light and it went dim almost immediately. Now I hadn't switched the store/use switch to use when I plugged into the generator, it had switched over automatically.
First question, does the store/use switch automatically switch to use when plugged into shore/generator power? I've not noticed before.
I checked the batteries and they were both 10-11v, obviously not feeling well and after being on the generator most of the day. The breaker hadn't tripped. I then turned the store/use switch to store and called it a day, figuring one or both batteries are finally giving up.
When I plugged the trailer in to shore power, lights are bright, A/C fan turns,~120v on the meter inside...all is well. Except the batteries are showing barely 11v and apparently no charge volts going to them. The store/use switch has now again, automatically switched to use so I "should" be getting a charge to the batteries. I checed voltage at the converter/charger (Parallax) and was getting 13+v to the batteries (at terminal C &D) but nothing at the batteries.
Just for grins I cycled the store/use switch off and then back on and voila, 13+ volts at the batteries!
Second question, has anybody had to cycle the store/use switch to get battery charging current to the batteries?
I thought that this, if correct, was leading to some unexpected battery charge levels over the past few years.
Thoughts??
B25guy is offline   Reply With Quote
Old 09-06-2006, 07:55 AM   #11
2006 30' Classic
Images: 14
Jdl--the reason for the cable lenth problem when switching from24-27 is the posts location on the 27s are opposite those of the 24. Not sure that was explained.---pieman
Old 10-26-2006, 02:59 PM   #12
Question
Any preference..pluses and minuses...deep cycle or standard??
George Jr.
George Jr. is offline   Reply With Quote
Old 10-26-2006, 04:26 PM   #13
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
A PowerPulse Desulfator would help extend the life of your batteries.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 10-26-2006, 04:49 PM   #14
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Have you considered upgrading to the AGM batteries? They're a bit pricey, but mine are still going strong. If they did need replacing, I would get the AGM's without hesitation.
http://tinyurl.com/y47l5q
SilverRanger is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
