04-13-2018, 01:21 PM
2022 25' Flying Cloud
NCR
, Ontario
upgraded PD4655 VL (lithium ) with Wildkat remote
I got the updated PD4655 VL to support my new battle born LION battery.
it came with a wildkat remote.
no do documenetaion on how to connect
there is now a button on the fuse board
i now have TWO mail plugs with THREE female connects.
how should it be wired?
1. forget the short 4 wire cable from power board to fuse board and connect the Wildkat directly to the power board.
2. ??
here is what it looks like.
i have circled the connectors in question
04-13-2018, 01:42 PM
2014 25' FB Flying Cloud
Des Peres
, Missouri
It should plug directly on to the board
Your right circled pic
04-13-2018, 02:15 PM
Silver Sojourn
2007 27' Classic FB
Excelsior
This thread may help with your install.
http://www.airforums.com/forums/f449...es-162905.html
The PD4655 LV install is the same as the PD4655. The PD4655 LV "Modified for Lithium" includes a jumper on the PC Board that overrides the Pendant Wizard and the 4 stage charging, see image. Therefore there's no need for the pendant or to override the charger to put in Boost Mode. The Pendant shouldn't be needed if the Jumper is set LI and not WIZ.
04-13-2018, 04:10 PM
NCR
, Ontario
thanks
what about H4
off-lead
on-gel
what should it be for li-on battery?
04-13-2018, 04:21 PM
Silver Sojourn
2007 27' Classic FB
Excelsior
[ATTACH]308636[/ATTACH
For Lithium it should be as shown in picture.
04-13-2018, 04:30 PM
NCR
, Ontario
im asking for the H4 posts that is left of the lion posts
04-13-2018, 09:01 PM
Silver Sojourn
2007 27' Classic FB
Excelsior
The board pictured is how it arrived, set up for Lithium. H4 was left open.
04-14-2018, 08:09 PM
2011 22' Sport
Portland
, Oregon
The remote does nothing with the lithium jumper set. FYI. As the Wizard is bypassed entirely by the Lithium jumper.
04-14-2018, 08:23 PM
NCR
, Ontario
@silverhousedreams
tnx
i will not install the new fuse board then as the only change is the boost button
i will just use the new power board and NOT install the remote boost button
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Where did you locate the Remote Pendant? PD4655 upgrade.
RxGuy |
Batteries, Univolts, Converters & Inverters |
14 |
02-05-2018 07:40 PM |
Upgraded My Batteries to Lithium - Woo Hoo!
burnsdl |
Electrical - Systems, Generators, Batteries & Solar |
21 |
12-02-2015 09:43 AM |
charge rate of PD4655
grizbear |
11 |
05-04-2015 01:29 PM |
PD4655 Converter Questions
RubyDog |
7 |
02-27-2015 05:25 AM |
PD4655 Converter
No. 13 |
80 |
10-17-2014 11:44 PM |
