Closed Thread
Old 12-09-2009, 09:13 AM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Upgrade this blue box with what??
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline
Old 12-09-2009, 09:51 AM   #2
Ag&Au's Avatar
Port Orchard , Washington
I'm not sure what it is, but if it's the blue color that you don't like, I think fuscia, with periwinkle accents would look nice.
Regards,
Ken
Ag&Au is offline
Old 12-09-2009, 09:52 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
What's wrong with the Inteli-Power on top of the blue box (Univolt). It is obviously hooked up.
Not sure how a 1970 is done, but the only reason I can see for the blue box is if the installer of the Inteli-Power connected to the fuses in the Univolt. Is the Univolt connected at all?
Vaughan
vswingfield is offline
Old 12-09-2009, 10:16 AM   #4
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Yes, the Univolt is hooked up. Honestly, Im is unsure what the function of the blue box. I see it has fuses and connects to the battery but in the scheme of things Im not sure what this does. Very much a newbie when it comes to 12v stuff
Its kinda a "while Im renovating" question to see if the blue box can be updated with a more energy saving model.
Old 12-09-2009, 10:18 AM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Regards,
Ken
HEY NOW...
Old 12-09-2009, 10:48 AM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by WILDRTEXAS View Post
The black cord across the Inteli Power. What is it to and is it plugged in?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline
Old 12-09-2009, 10:50 AM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
The blue box is the Univolt, while the Inteli-Power is a replacement. The large red wires from the Inteli-Power run to the battery. The fuses should run off into the trailer to supply power to the lights, etc.
Some Univolts had an internal fuse block and no fuse block in the trailer itself. My Excella, on the other hand, had the fuse block in the wall of the trailer above the Univolt. See http://www.airforums.com/forums/f449...0-a-57567.html for photos.
What you seem to have looks like a way to utilize the fuse block in the Univolt without having to add a new fuse block. It would be interesting to know where the two large red wires from the Inteli-Power are connected. Kind of hard to tell from the photo.
Is the Univolt (blue box) even connected to AC anywhere. I am inclined to doubt it from the photo.
Vaughan
Old 12-09-2009, 10:52 AM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Our posts crossed.
That is the AC power to the Inteli-Power, and you will have to answer the question about its connection to AC. That was my next question. Where does it go?
Vaughan
Old 12-09-2009, 03:09 PM   #9
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
I was plugged into the 110 outlet
Old 12-09-2009, 03:16 PM   #10
1967 22' Safari
1960 Caravel
Images: 8
Why did you unplug it?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-09-2009, 03:41 PM   #11
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Is this photo better?
Old 12-09-2009, 03:47 PM   #12
1967 22' Safari
1960 Caravel
Images: 8
OK the little silver box is the upgrade to the blue box. I bet the blue box is still there because it is being used as a fuse box. The little silver box is the one that is converting 120VAC to 12VDC.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-09-2009, 03:57 PM   #13
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
OK THEN, Is the little silver box a "little" upgrade to the big blue box? can the bule box be totally done away with? using a bigger silver box?
Old 12-09-2009, 04:05 PM   #14
1967 22' Safari
1960 Caravel
Images: 8
Yes, The lil' silver box is lil' upgrade to the big blue box.
Yes, If you get a new fuse box or cut the old fuse box away from the big blue box. Where all the wires are going in and out of the big blue box.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Closed Thread
Electrical Upgrade rc707 Electrical - Systems, Generators, Batteries & Solar 15 05-31-2008 08:17 PM
A little lighting upgrade thecatsandi Lights - Interior & Exterior 19 11-22-2007 08:28 AM
Lighting upgrade mkeith54 Electrical - Systems, Generators, Batteries & Solar 1 06-20-2005 08:00 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
