Closed Thread
Old 12-10-2009, 10:16 PM   #43
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Aage View Post
Terry, that's my problem exactly. I have the new converter, and I even bought a new distribution panel (fuse panel) but when I went to sketch out a plan to do the swap, I looked into the current Univolt's home there, in the corner of the closet, and I could NOT imagine how my big hands would be able to manoever in there to undo all the bolts.
I had a nightmare-type flash that I would be forced to remove the tub.
I asked when I was at JC, and they (half-jokingly, I thought) suggested that I get a 7-year old to do it for me.
On mine (and probably on yours too) there is a U-shaped metal cover over the Univolt, making the access to the rear bolts look impossible for an adult hand.
Any hints? Oh, just re-read your description, and you took out the closet wall adjacent to the tub, is that right?
I removed the floor in the closet, and removed the screws holding the plywood board holding the Univolt in place, and slid the plywood out through the hole. After I got it out, I placed the new converter on the plywood, and replaced it. Then I removed the old fuse panel from the Univolt, and bolted it to the divider wall where the access panel was. I then built a small cover for the fuse panel to keep anhything from coming in contact with it and causiung a short.
overlander63 is offline
Old 12-10-2009, 11:26 PM   #44
2xS
2xS's Avatar
1971 31' Sovereign
San Diego , California
Cool Kudos on getting that post removed...
But you know what, I'm still man enough to extract some relevant points from it:
1) When adding things to the trailer, be sure to choose lightweight materials so you don't overload your frame; perhaps consider having someone inspect your frame first.
2) Do research beyond what people tell you, especially 2xS (that guy is crazy!)...
See how easy and cordial that was? And without being a total jerk about it...
The fact is when you get there WILDR, you'll have to do SOMETHING with your bathroom as it is dismantled. I used some lightweight 3/8" water resistant luan from Home Depot as the paneling for the shower and counter face. Then I got waterproof tileboard (Home Depot again) and a whole lotta liquid nails: shower wall adhesive. I used a 3/4 plyboard for the counter top and glued down tiles with mastic and sealed the whole thing. Most all of the materials are super lightweight, and the weight difference between the old bathroom setup and new bathroom setup is negligible: +50lbs. maybe. Those pipes you see in the photo are under the pan; the line meets up with kitchen drain and has an air vent on each side of the pan. I left as much of the existing line as made sense.
As for the weight of the ARC that was in question, (don't look old dogs!), I believe I more than negotiated the weight difference after the first trip to the dump.
But hey, just a forewarning, I'm an electrical engineer and I have not been formally trained in the arts of construction or plumbing. I did however (and still do) have skillful people working with me throughout this process WHENEVER I was unsure about ANYTHING. My electrical advice and credentials though, I'd say, are pretty bulletproof. But you never know what jerks they let on the internet these days; they could be telling you anything...
By the way... how accurate was I with your univolt wiring? Have you had a chance to check it and see?
Good Luck!!!
Dennis W.
MPA, MBA, BSEE, PM1
ID:	92406   Click image for larger version
ID:	92408   Click image for larger version
Lasciate ogne speranza, voi ch'intrate
2xS is offline
Old 12-10-2009, 11:41 PM   #45
2xS
2xS's Avatar
1971 31' Sovereign
I'll second that... I don't think I removed the bathtub and wall there before I removed the Univolt... I'm pretty sure I was able to remove it while things were intact...
The instructions for removal suggest the same.
2xS is offline
Old 12-11-2009, 11:15 AM   #46
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Thank you for that suggestion.
ONE in every crowd! I wont spend another moment on HIS negative post wastes GOOD energy on a very fun hobby.
Loved your post on my thread. Enjoyed reading, the you tube and the the schematic. Thank you for all your time and effort. Your AS system is perfect for you. Its shows your an electrical engineer and very creative with the box. Mine AS will not be near as "electrically" entailed, a simple system for a simple yet happy trailer.
Happy Holidays and Thanks again.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline
Old 12-11-2009, 12:40 PM   #47
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Unintellipower Univolt Replacement
Introducing Unintellipower
Lumatic is offline
Old 12-11-2009, 02:10 PM   #48
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
LU That looks familiar...too familar
Old 12-11-2009, 02:13 PM   #49
2xS
2xS's Avatar
1971 31' Sovereign
Troubleshooting Electrical Systems Remotley...
Didn't mean to throw you off with my power supply... but I never gave any indication on how I actually built it... That post/blog hasn't been written yet, and I would NEVER advise someone to design one without about a year or three of electronics classes.
However, the 12V system handled by your Univolt you will apparently have no choice but to deal with. I was more interested in knowing if my wire identification was correct for your trailer e.g. blue wire = charge line, purple wire = kitchen +12V, white wire = ground etc... You can verify the connections using the continuity tester on any multimeter (DMM) e.g. connect one DMM lead to the connection in question and find the other end (same color wire) to your other DMM lead; you should do this for EVERY connection in your trailer to ensure you don't have an open anywhere. Once that test is complete, you can hook up power to your charge lines and measure the voltage between your lines. They should all be hooked up with your ground connection as the common connection; at this point, all of your +12V should read so on a DMM e.g. V_blue > V_white = 12V, V_purple > V_white = 12V, V_brown > V_white = 12V; where the connection to the red terminal on your DMM is the +Voltage, and the black terminal on your DMM is connected to -Voltage (white).
Good Luck!
P.S. You aren't in any danger messing with your 12V system, 12VDC cannot hurt you; at worst you'll see a spark if your 12V is on and you short a connection e.g. if the white wire touches any other wire, or if any wire (besides white) touches the shell in the trailer. The only way I've ever heard of someone hurting themselves with 12VDC is by shorting out connection on say a wedding ring; the conductive metal on a ring will heat up very quickly and burn you if you manage to get it between the any +12VDC connection and ground. Don't believe me? Try it yourself... find a car battery, and touch the positive terminal with one hand and the negative with the other. FYI: scaring people is fun, do the test with someone around and scream and shake like you're being electrocuted... Good Times!!!!
2xS is offline
Old 12-11-2009, 05:11 PM   #50
2xS
2xS's Avatar
1971 31' Sovereign
Originally Posted by VIKING View Post
Somebody with a couple of thousand posts under their belt is going to get my attention more than a relative newby, and though I may not like what they have to say, I know I have a better chance of getting good, relevant information.
Just a thought:
Perhaps some of the wisest ones read & research & listen more than they post.
"Great ideas often receive violent opposition from mediocre minds."
~Albert Einstein
2xS is offline
Old 12-11-2009, 05:15 PM   #51
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
400lbs added to the tongue weight of a 39yr old coach, good luck. What have you done to beef up the frame?
The workmanship on the ARC is excellent, the concept is excellent.
The placement, IMHO, not so much.
The original lasted 40 days and 40 nights, I hope that holds true for you.
Stream Safe
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
ROBERT CROSS is offline
Old 12-11-2009, 05:26 PM   #52
2xS
2xS's Avatar
1971 31' Sovereign
LMAO! Me too!!!!!!!!!
I had a professional inspect and reinforce the tongue and frame.... I let them know of my plans; the weight distribution has been meticulously scrutinized. Unfortunately, I'm not a welder so I took the monetary hit and left that one for the pros.
2xS is offline
Old 12-11-2009, 05:53 PM   #53
Lumatic's Avatar
1993 34' Excella
Images: 16
how to get relevent answers from highly competent long-time Airstreamers?
You can pretty much count on getting answers to questions you already know the answer to. So, if you say in your post you already know the answer to the question you are asking, but don't, you may increase the odds .
Lumatic is offline
Old 12-11-2009, 06:01 PM   #54
VIKING's Avatar
Boulder Creek , California
Just a thought:
~Albert Einstein
True 2xs, but how do you know if they are wise if they are not sharing their wisdom?
What 2air had to say about gathering good information was a "great idea"(see Einstein quote above) and is more important than a lot of people know. It takes time to learn how to get to the really good info here and his suggestions were meant to help those seeking that info find it.
There are also some very helpful folks who do not know what they are talking about, yet they have a lot to say. This is where newbies get into trouble. Having some idea of the skill level and experience of the person you are taking advise from is the best way to filter out the irrelevant stuff as far as I can tell.
With regard to your posting about the ARC, I would be fascinated to hear about the rest of the story, like how do you off-set the weight of the unit? (Extremely important information) A relative new-comer might just think that adding another 5 to 6 hundred pounds at the other end would do the trick!
How loud are the fans? Can you sleep with them running within a foot or two of your head? How do you vent the batteries to the outside?
I'm not trying to knock your idea. I really am fascinated with it, I just want to see how well thought-out this is. The answers to these questions could possibly help you and others here to understand all of the ramifications of this kind of modification, such as: front-to-back balance, tongue weight increase, GVW increase, axle capacities, battery expense and longevity, etc.
And don't forget about the benefits of the system like: how long you can boondock for at a time, and how you could power your house from your Airstream in an emergency.
Looking for more info....
Rich the Viking
VIKING is offline
Old 12-11-2009, 06:02 PM   #55
Ottawa , ON
:hew:: That's good to know! Please post a few pictures of the work the pro did to reinforce the frame?
You take great pictures, by the way.
Aage is offline
Old 12-11-2009, 06:41 PM   #56
2xS
2xS's Avatar
1971 31' Sovereign
Very thoughtful posts there....
Understanding the problem in as great 'a detail as you can is always the best start to the best solution; 2air's suggestion on digging further information was never a bad one. The thread just had no tact.
Let me gather specs and info and write up a formal technical specification sheet for the modifications I made to install the power supply and for the supply itself... It'll take a little time of course, I am about 80% complete on my work for the trailer (which means it's probably more like 60%, right???), and am trying to get it road ready as quickly as possible. I'll also need to allocate measuring instruments for several of the calculations being requested. Plus there are cad designs, load cell data to sift through, etc... The info will require a bit more effort to obtain and formalize into something suitable for presentation. I'll notify all curious members in this thread when I post it, and I'll keep quiet about it until then.
This all started because I'm Mr. Worst Case Scenario, and if the whole world goes to crap (which it could), I might not have propane, but I'll still have hot water and electricity...
I must admit I'm surprised it has gotten the attention it has...
I'll keep you posted!
2xS is offline
Closed Thread
Electrical Upgrade rc707 Electrical - Systems, Generators, Batteries & Solar 15 05-31-2008 08:17 PM
A little lighting upgrade thecatsandi Lights - Interior & Exterior 19 11-22-2007 08:28 AM
Lighting upgrade mkeith54 Electrical - Systems, Generators, Batteries & Solar 1 06-20-2005 08:00 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
