Closed Thread
Old 12-09-2009, 09:47 PM   #29
Ottawa , ON
Originally Posted by WILDRTEXAS View Post
aage, was planning to move my battery to under he curbside twin instead of putting it back in the rear. Is this a Bad Idea??
Yep, I'm afraid it is. Greater minds than mine can tell you exactly why, but it seems certain that it's not advisable.
Aage is offline
Old 12-09-2009, 09:55 PM   #30
Ottawa , ON
Originally Posted by overlander63 View Post
At least yours is out in the open, I had to tear apart a closet and dig under the bathtub to get at the one I replaced.
Terry, that's my problem exactly. I have the new converter, and I even bought a new distribution panel (fuse panel) but when I went to sketch out a plan to do the swap, I looked into the current Univolt's home there, in the corner of the closet, and I could NOT imagine how my big hands would be able to manoever in there to undo all the bolts.
I had a nightmare-type flash that I would be forced to remove the tub.
I asked when I was at JC, and they (half-jokingly, I thought) suggested that I get a 7-year old to do it for me.
On mine (and probably on yours too) there is a U-shaped metal cover over the Univolt, making the access to the rear bolts look impossible for an adult hand.
Any hints? Oh, just re-read your description, and you took out the closet wall adjacent to the tub, is that right?
Aage is offline
Old 12-09-2009, 10:11 PM   #31
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
It's never as simple as a yes or a no on most any subject.
http://www.airforums.com/forums/f449...box-58059.html
http://www.airforums.com/forums/f449...ery-40049.html
On both my Airstreams I have batteries that live inside. I have updated converters and have sealed batteries. Even with sealed batteries vent tubes are suggested. Do your research.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline
Old 12-09-2009, 11:05 PM   #32
2xS
2xS's Avatar
1971 31' Sovereign
San Diego , California
Originally Posted by Aage View Post
I'm guessing, due to its shape, that this will go across the front of the trailer. Have you done any calculations on what the impact on your tongue weight will be, once all 6 batteries are loaded?
Also, do you plan to ensure that the Arc is isolated from the trailer's air space? I believe that there is a safety reason for making sure that such is the case. You probably noticed that the original battery space was only open to the outside, and not the trailer's interior.
Perhaps the fans are designed to vent to the outdoors?
The ARC actually weighs less than the Univolt!!! But seriously, each battery alone is about 50lbs. x 6, and the rest of it combined (including framework) is probably about 100lbs-125lbs. So the whole thing total is about 400lbs. What can I say? Electricity is mandatory, after all, I hold a BS in Electrical Engineering.
The ARC is installed in the forward portion of the trailer.
The ventilation system utilizes air from inside the trailer, and it only kicks on when the temperature inside reaches my desired set point. I suppose I could route it out, but at the moment, I'm trying to keep in any warm air I got inside. Several detectors are used to ensure I'm not dying for my electricity.
And as long as you insulate the terminals on the battery, and you have an AGM battery; it shouldn't matter where you put it. The only concern is if your battery charger overcharges the battery as this is what causes hydrogen pockets; in other words, get a microcontroller based charging system to help eliminate that possibility. But planning an enclosure with ventilation to the outside is probably the safest idea... There are several options for an outside vent if you'd like to place it under the twin: 1) the trunk space in that same area, or 2) you could tap the air vents for the drains; one will be accessible under your kitchen counter behind the sink, and another would be in the passenger closet.
And Aage... you know that tub has to go anyways
ID:	92357   Click image for larger version
ID:	92359   Click image for larger version
Lasciate ogne speranza, voi ch'intrate
2xS is offline
Old 12-10-2009, 06:08 AM   #33
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My experience only....I may just wait 'til a problem shows it's ugly little face before replacing full speed ahead...
http://www.airforums.com/forums/f449...ems-55549.html
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
ROBERT CROSS is offline
Old 12-10-2009, 06:25 AM   #34
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Wow,
Dennis has a serious boondocking setup....just add a solar panel or two.......
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
Alwhisman is offline
Old 12-10-2009, 09:21 AM   #35
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
ahead...
AMEN... Then the rear floor rot rears its UGLY head
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline
Old 12-10-2009, 09:24 AM   #36
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Diggin your tub replacement. Where did you get the pan? Did you need to reroute the drain? Is the top braced as a seat? Lookin good!
Old 12-10-2009, 11:33 AM   #37
2xS
2xS's Avatar
1971 31' Sovereign
Boondockin' someday... today I get to pull out a bad furnace... BBBBBBBRRRRRRRRRR
I replaced the tub with a 32"x32" shower pan. It was the largest size I could get to fit in the space. I got the pan at Lowes; I believe it was about $120. No special order: it was just there on the shelf. Then I got to rebuild the counter and all that; yay! The tile bathroom counter does double as a seat; I made sure of that with some 90 degree brackets, rivets, and a whole lotta support structure.
I did need to reroute the drain; the tub was like 22"x44" and its' drain was in the middle closer to the edge by the door. My pan had the drain dead center. It wasn't too far off though. I had to cut away a little more of the floor there in order to make it happen. I managed to be able to tap the existing drain line and with a couple fancy ABS angles and some luck trying to set the pan on the fitting and in the spot. It wan't easy, but knowing I won't have to sit down to shower (in a tub that was disintegrating) makes all the effort well worth it.
ID:	92379   Click image for larger version
2xS is offline
Old 12-10-2009, 11:36 AM   #38
2xS
2xS's Avatar
1971 31' Sovereign
Thanks!
I think I'm going to try my hand with a wind turbine though. I found a $450 unit that pulls 400W. Solar just can't do that....
Amazon.com: Sunforce 44444 12-Volt 400-Watt Wind Generator: Automotive
2xS is offline
Old 12-10-2009, 01:05 PM   #39
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
PRICELESS!!
Thanks for the photos...
Im very visual and this too is PRICELESS
Cynthia
Old 12-10-2009, 01:10 PM   #40
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Oh yeah, what material did you wrap the pan with? The sheet vinyl?
How about the counter/seat the tiles? Are they on a hardi backer type material or just glued down on subtop?
Old 12-10-2009, 01:30 PM   #41
Thanks!
I tried that one last Spring. Nice unit....but. I found there was no convenient, way of adapting it for portable use. They no longer supply the mobile tower needed, and it was rather bulky and hard to store. Kind of a pain to remove/install the blades every time.
Where we "dock" the tower would have to be too tall to get above the tree-line.
It was a very well made unit though and if your are able to find a suitable tower and have enough wind, (steady above 15mph) it should work very well.
PFC
"Tahawus"
RLC
John Prine
Old 12-10-2009, 09:10 PM   #42
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
The Univolt
Think I have the same configuration, an Intellicharger sitting on top of the old univolt, using the original fuse block. Must have been a common upgrade path and a pain to remove.
RichHog is offline
Closed Thread
Electrical Upgrade rc707 Electrical - Systems, Generators, Batteries & Solar 15 05-31-2008 08:17 PM
A little lighting upgrade thecatsandi Lights - Interior & Exterior 19 11-22-2007 08:28 AM
Lighting upgrade mkeith54 Electrical - Systems, Generators, Batteries & Solar 1 06-20-2005 08:00 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
