Old 09-14-2010, 06:43 AM   #1
1977 Argosy 28
Mahone Bay , Nova Scotia
Univolt upgrade for a 76 Argosy
I have redone a 1976 Argosy.
I have added 12 volt lights , replaced the fridge unit [now has a 12volt circuit to start the propane ignitor] and replaced the 3 vent fans This has resulted in more demands on my 12 volt system. Lights dim , fans slow, and the warning light on the fridge illuminates when using multiple circuits .
The univolt system is the original unit. The 12 volt panel is a main line 50 amp [ univolt / battery],followed by a 30 amp [main charged line ] , then 4 -20amp circuits .
Should the system be uo-graded to a 80 amp univolt ? Would this solve my problem ?
If not what would ?
Al
molliesdad is offline   Reply With Quote
Old 09-14-2010, 08:13 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Suggest:
look around in the electrical section a while.
Batteries, Univolts, Converters & Inverters - Airstream Forums
kennethowens is offline   Reply With Quote
Old 09-14-2010, 10:06 AM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Sounds more like a bad ground or corroded battery cables or a bad battery.
Replacing the Univolt is a good idea go with a 3 stage charge 55 amps should be plenty.
I replaced mine with a 65 amp Progressive Dynamics 9265 and real happy with it.
I kept the Univolt fuse panel.
Garry
Univolt Replacement in 1976 Argosy M/H idahohanson Mechanics Corner - Engines, Transmission & More... 4 07-21-2015 08:50 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
1979 Argosy Univolt problem??? nick6930 Batteries, Univolts, Converters & Inverters 9 02-10-2009 05:23 AM
'78 Argosy Electrical Problems - Univolt? texas_argosy Argosy Motorhomes 3 11-06-2006 03:43 AM
