Old 06-13-2009, 11:29 PM   #1
coairstream's Avatar
1964 22' Safari
Denver , Colorado
Univolt TU-345A Humming
I think its the original and it seems to works good, but humms loud. I have a 1972 Trade Wind. I pulled it out because I'm redoing the bathroom, but don't want to reinstall it if its a concern. A local repair shop said humming is common, but the more opinions the better.
coairstream is offline   Reply With Quote
Old 06-14-2009, 01:12 AM   #2
The humming, is caused by loose laminations in the transformer, that's in the Univolt.
If you have plenty of time, you can repot the transformer, which will cure the hum.
If you want to know how to repot it, let me know.
Old 06-14-2009, 04:02 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yup...humming is common, so common in fact many people installed switches to turn them off at night Unless you are bent on a perfect restoration I would consider an upgrade to something like the Intelipower. Technology marches on and the Uni-volt is one piece of old technology I can do with out. The newer ones are solid state, quieter and are better for your batteries.
Aaron
WBCCI #XXXX AIR #2495
Old 06-14-2009, 07:07 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
They hum, and boil batteries dry, if your not careful and watch the water level in the battery. We opted for an upgrade to a modern charger/converter and found it worth the expense.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-14-2009, 09:15 AM   #5
1964 22' Safari
Denver , Colorado
Thanks Andy I would be curious about the repot. Please let me know.
Cody
Old 06-14-2009, 09:19 AM   #6
1964 22' Safari
Denver , Colorado
Aaron,
Thanks I'll look into the intelipower. I did by a new better battery so thats a concern as well.
Old 06-14-2009, 11:48 AM   #7
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Cool
The truth of Its, I have been staying In my 73 a lot after the fire In the 91.. I have come to the conclusion I missss that buzzzing on my afternoon naps especial In a noise campgrounds!! In the 91 I always have music or a fan on for background noise all the time. In the 73 no need It has Its own (BUZZ)!!!!
DIMMER
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
Old 06-14-2009, 01:38 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Mine hums, never trashed a battery since I went to sealed ones. I just shut down the GFI when we hit the hay.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-14-2009, 03:38 PM   #9
Cody
Cody.
Remove the transformer.
Soak it for a couple of days, and rotate it every few hours.
The liguid is simple varnish.
After acouple of days, remove the transformer and let it air dry for a couple of days.
Then reinstall it.
The hum will be gone.
And it's a lot cheaper than a new Univolt, regardless of brand.
Old 06-16-2009, 10:02 AM   #10
1964 22' Safari
Denver , Colorado
Andy THANKS I'll do that... Which one is the transformer? What should I soak it in?
Old 06-16-2009, 11:01 AM   #11
Take the cover off the univilt.
You will see the transformer.
Write down which wire goes to whatever.
Check post #10 above for instructions as to how to do it.
VARNISH is the potting material.
Old 06-29-2009, 01:45 PM   #12
1964 22' Safari
Denver , Colorado
Andy,
I went to take the Univolt apart this weekend and noticed the cover was riveted together. Should I just drill them out?
Old 06-29-2009, 02:08 PM   #13
Andy,
Just drill them out and remove the cover.
There is nothing you can hurt by doing that.
Old 06-29-2009, 02:45 PM   #14
1964 22' Safari
Denver , Colorado
Sounds good and thanks again for the help. I'll do it and take a picture before I start pulling wires. I'll post the pics by the end of the day tomorrow.
univolt humming slvrbulit Batteries, Univolts, Converters & Inverters 5 04-23-2009 07:04 AM
Brakes humming msmst25 Brakes & Brake Controllers 4 08-19-2008 06:28 PM
Humming Univolt Holland Electrical - Systems, Generators, Batteries & Solar 11 01-26-2006 10:27 AM
Univolt HUMMING! markparker22 Electrical - Systems, Generators, Batteries & Solar 18 10-12-2004 10:44 AM
Univolt - its warm but humming! Bryanhu Electrical - Systems, Generators, Batteries & Solar 2 04-03-2004 06:30 PM
