Old 06-29-2009, 06:57 PM   #15
coairstream's Avatar
1964 22' Safari
Denver , Colorado
Ok so I romoved the cover. This thing looks old, but Im up to giving it a shot. Now which on(s) is the transformer? Most of it is saudered together.
coairstream is offline   Reply With Quote
Old 06-29-2009, 07:10 PM   #16
1964 22' Safari
Denver , Colorado
Ok Andy so I took off the cover and this thing looks OLD!!! But Im up to giving this a shot. Now which one is the transformer or transformers. Most of it is saudered together.
Old 06-29-2009, 09:35 PM   #17
The part that is at the very left of your photo, is the transformer, that may be in a box.
Old 06-30-2009, 01:05 PM   #18
1964 22' Safari
Denver , Colorado
Andy,
It looks almost impossible to remove without taking the entire thing apart and even then I think it might be adhered to to cover in some way as I think it was originally like that because of the heat factor. What if I were to do this? I can leave it assembled and stand it upright in a bucket with the transformer at the bottom. I can then fill the bucket with varnish to the point on it being emerged without getting to the other components. Leave it that way for several days then let it dry out. I wont be able to rotate it, but if it is completely emerged and soaking for a few days maybe it will get there. Ill also let it dry for a few weeks and keep it in the sun so it will evaporate as much as possible. One other question. With varnish being flammable and an inverter getting hot should I be concerned for on down the road when its hooked up?
ID:	83230   Click image for larger version
Old 06-30-2009, 02:48 PM   #19
Andy,
Your transformer is already potted and encased.
The repotting can only take place with the actual transformer, without any covers or encasing.
Varnish has been used to pot transformers, for as long as varnish has been around.
I don't have any other suggestions for you to try, other than creating a sound barrier.
Old 06-30-2009, 04:17 PM   #20
1964 22' Safari
Denver , Colorado
Andy,
Thanks again for the help. I just went back into the garage and looked at it again the tan stuff in the picture above almost like stiro-foam is literally glued to the metal box around it. The only way I see to get it off is to chisel at it which probably is not a good idea. Maybe its best to leave it alone if my idea would not work, or buy a new one.
Old 06-30-2009, 05:40 PM   #21
1971 25' Caravanner
scappoose , Oregon
Unless you absolutly must have a "perfect, period correct trailer", there is no future in univolts. The modern three stage chargers are so far superior, that there is no second place. Univolts belong in a museum, or the trash.
rangebowdrie is offline   Reply With Quote
Old 06-30-2009, 06:03 PM   #22
1964 22' Safari
Denver , Colorado
What would you recomend replacinf it with???
Old 06-30-2009, 06:04 PM   #23
1964 22' Safari
Denver , Colorado
replacing
Old 07-04-2009, 12:09 PM   #24
1974 25' Tradewind
Ann Arbor , Michigan
See the intellipower mentioned by Aaron in #3. Looks like a good unit. Looks like Andy (inlandrv.com) has the original style univolts at $195. Mine hums quite a lot, so I plan on giving varnishing a try this fall perhaps.
powool is offline   Reply With Quote
Old 07-08-2009, 07:36 PM   #25
1964 22' Safari
Denver , Colorado
Andy what do you think repot or not?
Andy,
Before trashing it I decided to give it one more shot!!! I took it apart and did the only thing I could which was to start cutting away at the metal since the two were practically bonded. In doing so I think it is damaged. Much of the crystal like material is coming off with the metal, and is lose. Ive stopped for now, but can continue if it is still salvageable. Believe it or not I would rather this work than have to buy another and I'm very curious now. Let me know what you think or does it go in the trash?
Thanks Cody
Old 07-09-2009, 07:24 AM   #26
1974 25' Tradewind
It looks to me like it has been exposed to a lot of water, and this is never a good thing. If that were mine, I'd toss it at this point - both the inner and outer cases are in bad shape. I think that in theory you can salvage it, but I'd be leery of putting a repaired unit that looked like that back into my trailer.
univolt humming slvrbulit Batteries, Univolts, Converters & Inverters 5 04-23-2009 07:04 AM
Brakes humming msmst25 Brakes & Brake Controllers 4 08-19-2008 06:28 PM
Humming Univolt Holland Electrical - Systems, Generators, Batteries & Solar 11 01-26-2006 10:27 AM
Univolt HUMMING! markparker22 Electrical - Systems, Generators, Batteries & Solar 18 10-12-2004 10:44 AM
Univolt - its warm but humming! Bryanhu Electrical - Systems, Generators, Batteries & Solar 2 04-03-2004 06:30 PM
