Old 09-27-2012, 12:37 PM   #1
Safari66's Avatar
1966 22' Safari
Dallas , Texas
Univolt to Intellipower 9200 series
I'm replacing my univolt with an intellipower 9200 in a1966 safari. I just got the intellipower in and have been looking at different methods of installation. My univolt had two sets of wires running to it, one bundle was red white and blue and the other was black and white. There were three fuses mounted on the unit. My intellipower has a male plug on it but I have no female receptacle on my trailer where the univolt was. I'm trying to figure out how to get this installed. Will I need to buy a fuse panel? Or is the pictured panel my fuse panel. And how do I plug this darn thing in?
Panel my battery hooks up to
Fuses on old univolt
This is where the white wire ends up
Where univolt was
Safari66 is offline   Reply With Quote
Old 09-27-2012, 02:34 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Your Intellipower requires four connections:
1. You must ground it
2. You must pug it into a properly intalled, standard 120VAC receptacle*
3. You must connect the positive 12 volt DC battery lead
4. You must connect the negative 12 volt DC battery lead
If this doesn't make sense, please get someone to assist you.
Please ensure that your Airstream is not plugged in to shore power and
Disconnect your battery terminals before installing your converter
* Ensure the 120 VAC receptacle is properly installed with correct polarity!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Univolt question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-19-2011 08:15 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
Replacing the original 1970 univolt charger with a new Intellipower 9200-series ranger_rick Batteries, Univolts, Converters & Inverters 5 02-08-2011 07:23 PM
