1976 31' Sovereign
2000 33' Land Yacht
Ball Ground
, Georgia
Univolt shunt
I replaced my univolt.Out of couriosty I took the univolt apart to see what the shunt looked like and see if I could figure out how and if it was worth installing to allow the amp meter to work. Its not clear what it looks like. I assumed it was obovious. The only thing that might be is an item in a heat shield. If I can find it is it easy to wire? Is the smaller white wire go to this circuit. Is this more work then benificial.Thanks for any help.
Common Sense
The meter shunt is a small diameter (about 1/8 to 1/4"), and if I remember correctly, about 1 1/2" long wire wound resister and should be mounted on the distribution/fuse panel.
GAT, in my 1971, it was a piece of copper with brass nuts and bolts...I tried to adapt it, when the new converter was put in my rig, but I never did get it to work. I even followed the schematics folks put up on this site, but it never worked...I also had NyCo rebuild the ammeter too.
__________________ Frederic 1971 Sovereign International - SOLD
2004 F-350 King Ranch AIR # 8239 EX-WBCCI # 8371
