Old 09-06-2010, 09:42 PM   #1
Newberry , Florida
Univolt Replacement
I'm dumping the old univolt and considering the Inteli-Power 9245. This new unit advertises low line voltage protection...therefore, do I not need to install a fuse panel as everything downstream from the 9245 is protected?
Overlander is offline   Reply With Quote
Old 09-06-2010, 09:47 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The low line protection is from low AC voltage to the unit.
You still need fuse protection for the DC circuits. The DC fuse panel is where the converter ties to the battery as well as distributes 12 volts to the trailer.
Richard
Old 09-06-2010, 11:42 PM   #3
Unfused electrical circuits can be a "fire" hazard, when you least expect it.
Fuses protect electrical circuits "AND" peoples lives.
Old 09-10-2010, 06:55 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Take a look at progresive 9245 load center. Gives you a 9245 converter w/ charge wizzard. Five 110 volt circuits, twelve 12 volt circuits. Makes a nice neat package. Only extra thing you need to buy is the 12v fuses, the 110v breakers and a couple bags of wire connectors. If the converter should go bad after warrentee cut and splice in a new one, two wires. The panel remains as is. I got one delivered for $135.00 from Vintage Technologies. So easy to install its fun.
putback is offline   Reply With Quote
Old 09-10-2010, 07:42 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Unintellipower
You can use the Univolt fuse panel in several ways. Here is what I did.
Univolt replacement Dogs & Us Electrical - Systems, Generators, Batteries & Solar 0 08-01-2010 11:11 AM
Univolt replacement? Apache_Camp All Argosy Trailers 10 09-25-2009 01:50 PM
Univolt Replacement TShepherd Batteries, Univolts, Converters & Inverters 18 02-17-2008 03:47 PM
Replacement for my Univolt wingfoot321 Batteries, Univolts, Converters & Inverters 15 05-14-2007 09:17 AM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
