Old 12-19-2011, 10:08 AM   #1
1985 29' Sovereign
Richmond , Virginia
Univolt question
My recently bought '85 Soveriegn has a Triad-ultra Model Tu-750-6 convertor, which my research suggests is the original univolt for my trailer. I'm pretty sure it is bad, but after taking out the sofa to get a better look I noticed the following which confuses me.
There is a wire coming from the univolt to a standard household light switch lying on the floor under the sofa. Then a return wire from the switch that is plugged into a normal 120V outlet above the univolt.
What is this switch for? Is it to tell the univolt to start charging the batteries when the trailer is hooked to shore power?
Thanks! Don't know what I would do without you guys...
Stonew98 is offline   Reply With Quote
Old 12-19-2011, 10:15 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like the switch is used to turn the Univolt on and off. Maybe a PO installed it to prevent the over charging of the battery(s). Do you hear a humming sound from the Univolt when the switch is on?
Old 12-19-2011, 10:24 AM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, not uncommon for a PO to have added a switch to either turn the univolt off due to noise, or to reduce the chances of overcharging the batteries.
The best thing you can do with the Univolt is to replace it with something modern and effective, such as a Progressive Dynamics 9245.
Old 12-19-2011, 10:34 AM   #4
1985 29' Sovereign
Richmond , Virginia
Thanks all...am planning to replace the Univolt. When I flip the switch nothing at all happens with the Univolt, which in addition to the fact that my batteries are not being charged while hooked to shore power suggests the unit does not work...but will check all circuit breakers and/or fuses first.
Thanks again!
Old 12-19-2011, 12:03 PM   #5
1985 31' Limited
Nellysford , Virginia
Univolt
My '85 had the same thing. Put in by the PO to turn Univolt off so it would not overcharge the batteries. I replace my Univolt with a Progressive Dynamics 9260 and I am very pleased with the results. It cycles through the various charge cycles automatically.
RTurnConn is offline   Reply With Quote
Old 12-19-2011, 12:22 PM   #6
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Seems to have been a trend. Ours is an 84 Sovereign. Same light switch for the univolt. Turn it on when you are hooked to shore power. And off when not. I also went with the 9260. Now I just let it work thru the cycles.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 12-19-2011, 02:40 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would just like to ask,why?
If the switch is between the wall outlet and the univolt why would one need to switch it off when not plugged into shore power? If not plugged in to shore power, there would be no 120 volt power going to the univolt in the first place.
I can see switching the connection between the batteries and the univolt to keep the charging under control, but if one switches the AC power off to the univolt, the 12 volt items in the trailer would be running on battery only. And not for very long.....
Or am I missing something?
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-19-2011, 05:05 PM   #8
casa3805's Avatar
Images: 41
You did not miss anything- I misspoke. My guidance when I bought it was to leave it on when camping and on shore power, but to turn off when storing, still hooked to shore power. Point being that if there was no drain, you could ruin the batteries.
Chuck & Skye
WBCCI 3805
Old 12-19-2011, 05:29 PM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Turning the UniVolt off at night would eliminate he hummmmm.
Richard
Old 12-19-2011, 06:09 PM   #10
casa3805's Avatar
Images: 41
So did replacing it with an Intelipower 9260.
Of course I wish I had placed that blinking green led light somewhere other than right in my sight line from the bed...
Chuck & Skye
WBCCI 3805
Old 12-19-2011, 07:47 PM   #11
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Amazing just how bright it is at night. I'm lucky, mine's behind a tambour door.....Phil.
pgr32e is offline   Reply With Quote
Old 12-19-2011, 08:15 PM   #12
Ottawa , ON
A tiny piece of electrical tape will fix that! I had to do that to the TV in our sleeping quarters, the tiny little red "off" light drove me crazy!
Well, crazier...
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Intel power question scorpiontimo Batteries, Univolts, Converters & Inverters 4 08-19-2011 08:43 PM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
Univolt output voltage question GeocamperAS Batteries, Univolts, Converters & Inverters 8 07-13-2011 10:22 PM
