Old 10-06-2009, 02:27 PM   #15
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Originally Posted by StingrayL82 View Post
Double check those fuse ratings...The trailer battery red fuse is rated AGU 50 amp, not 40. The car battery blue fuse is rated AGU 40 amp.
on edit: Just took a pic, for reference and, yes, I am becoming a UniVolt collector . The disassembled UniVolt on the right is from a 1971. The main one pictured is from a 1970:
Mine is fused like you said, 50/50/40 amp. I have a 50 amp on the positive AND the negative legs going to the trailer battery. A 40 amp on the blue wire from the car battery.
$Bill, look at the front cover on the Univolt (the cover over the fuse panel). If you have a 45 amp model Univolt, you probably need to step up to 50/50/40 amp fuses. Also, the amperage rating on for each fuse is printed underneath each fuse holder on mine, FWIW.
Stingray, I have another Univolt to add to collection if you want it. It's replacement should be here tomorrow. Just don't ask me to drive back to San Angelo to deliver it.
www.nesa.org
Air No. 6427
Old 10-06-2009, 03:50 PM   #16
whitley city , Kentucky
It is the 45 amp unit. It uses a 40 amp on the blue battery wire. It uses a 50 amp fuse on the red trailer wire. I am not sure what it is supposed to have on the black Ground wire, it is not marked.
$bill is offline   Reply With Quote
Old 10-06-2009, 04:06 PM   #17
Got gandkids?
I can provide a couple of pictures if you need them. Just let me know....
I'm not sure if it's original, but the negative cable to the trailer battery also had a 50 amp fuse. Are you still having problems? What is working and what isn't? I have a thread that describes what all of the these wires power, if you need it. I'll go find the posts and get back in a few.
www.nesa.org
Air No. 6427
Old 10-06-2009, 04:12 PM   #18
Only the plugins and AC are working. The lights , radio and jack have stopped working. When you hook a battey up it blows a fuse. When hooked to 110V only 110V stuff is working.
Old 10-06-2009, 04:22 PM   #19
Got gandkids?
Take a look at this thread beginning at post 360: http://www.airforums.com/forums/f226...tml#post326154
That will give you some idea how the 12 volt DC and 110 volt AC is wired. Your trailer may be a little different, but probably not by much.
www.nesa.org
Air No. 6427
Old 10-06-2009, 04:28 PM   #20
Got gandkids?
So it sounds like all of your 110v is working properly, right?
You are having problems with the 12 volt stuff (only), right? The fuse only blows when you hook up the battery to the Univolt? In other words, when the battery is disconnected, all of the 12 volt stuff works? No blown fuses?
www.nesa.org
Air No. 6427
Old 10-06-2009, 05:41 PM   #21
With the battery disconnected none of the 12v stuff works either.
Old 10-06-2009, 05:57 PM   #22
The univolt is running, I can hear it hum. I have checked all the fuses several times, none of them are blown. Nothing on the 12v side is working when it is plugged in to 110V. It blows afuse when you hook up a battery. It has been raining since I have gotten home from work, I was going to try to take the Univolt out.
Old 10-06-2009, 05:57 PM   #23
Got gandkids?
Are you sure that the Univolt is actually outputting 12 volt voltage? Do you have a multi-meter to measure the voltage coming out of the Univolt?
www.nesa.org
Air No. 6427
Old 10-06-2009, 06:13 PM   #24
I don't think that it is outputting 12v. I don't have a multi-meter, but I can borrow one if I need to.
It is odd the Univolt was doing its job friday night, but when I got back saturday morning it was'nt converting anything to 12v. It is still humming like it is doing something.
Thanks, Bill
Old 10-06-2009, 06:20 PM   #25
The jack on the tongue, which is 12v runs very faintly when the camper is plugged into 110v. When hook I hook the camper up to vehicle th jack works ike it is supposed to.
Old 10-06-2009, 06:28 PM   #26
Got gandkids?
I think it's probably time to get that test set. My Univolt still works after 36 years, but not very well, so I've ordered a replacement for it. A multi-meter would help to find the problem. And I'm not surprised that the Univolt worked one day, but not the next simply because of the age of the device.
www.nesa.org
Air No. 6427
Old 10-06-2009, 06:37 PM   #27
Update
I just went out and plugged it into 110v (with a wet extension cord) and everything is working. I had'nt touched it since last night. The only person who had been in it today was my wife. (hanging curtains) I guess she fixed the electrial problem while she was out there.lol It still leaves me wandering what the problem was. I will give another update tomorrow to tell if eveything is up and running.
Thanks everyone, Bill
Old 10-06-2009, 06:40 PM   #28
What are you replacing yours with? I plan on stripping mine down this spring and updating.
Univolt replacement Question Tim Bloodwor Batteries, Univolts, Converters & Inverters 7 07-14-2009 08:37 AM
Electrical / Univolt question pamelake Electrical - Systems, Generators, Batteries & Solar 4 01-15-2007 05:29 PM
Another Univolt Question higgy116 Electrical - Systems, Generators, Batteries & Solar 9 05-12-2006 11:35 AM
Univolt question viners Electrical - Systems, Generators, Batteries & Solar 9 03-25-2005 10:40 PM
Univolt question overlander76 Electrical - Systems, Generators, Batteries & Solar 12 07-08-2003 02:10 PM
