Old 04-09-2009, 08:47 PM   #1
1973 31' Sovereign
Unhappy Univolt or 12v System Gone Wrong
I got home from my latest adventure and found that my fiance had left interior lights on with out us being hooked up to shore power. The battery was basically dead according to meter on panel but lights were still on. I plugged in but now the univolt in the closet keeps cycling on and off and the panel lights brighten and dim when this occurs. What happened is the battery toast? I have a fully warranty so this is easy to solve or do I have other problems?
Thanks for any help.
Andy O
AustinAir is offline   Reply With Quote
Old 04-09-2009, 08:58 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The converter is trying to charge a dead battery and most likely going off on overload. The converter can not supply the current necessary to charge a dead battery.
Disconnect the battery and charge it with a battery charge for 24 hours and then test the battery. It should read above 12.7 volts once disconnected from the charger.
2004 Excursion 4x4
Old 04-09-2009, 09:04 PM   #3
New Borockton , Alabama
Images: 21
Andy,
Let the batteries charge for a few days and reevaluate. Univolts are horrible chargers but will eventually get them back up maybe with minimal damage. Like a car battery, they will never be the same if they went totally flat but you might be able to nurse some months or years out of them. I assume you mean the battery warranty and not the 73 sov warranty. Hang in there.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 04-09-2009, 09:59 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
12 v systems can behave very bizarre when the battery is drained, kind of like you have gremlins. As said above, shut everything down and plug it in, or use a auto battery charger. Keep in mind batteries do not like to be drained. It reduces their life expectancy.
Old 04-09-2009, 11:10 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, as stated above, recharge your batteries for 24 hours or more. But what wasn't mentioned is that you want to charge them at 2 Amps or less. Turn everything off or disconnect your batteries while charging.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
12v
63 Overlander 12V system rvnpikes Electrical - Systems, Generators, Batteries & Solar 2 10-09-2008 09:53 AM
69 Safari Univolt system Protosport Batteries, Univolts, Converters & Inverters 2 05-28-2008 03:02 PM
Univolt System for charging rozwd Electrical - Systems, Generators, Batteries & Solar 9 10-02-2006 07:50 PM
Replacing Univolt and 12V confusion sander17 Batteries, Univolts, Converters & Inverters 8 06-29-2004 09:09 AM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
