Old 09-03-2012, 02:22 PM   #1
Mossiyjack's Avatar
1973 31' Sovereign
Cornville , Arizona
Univolt/Onin
I have just purchased a '73 rear bedroom/center bath unit and am deep into redoing same. The electical has some interesting problems, to wit: The univolt is only putting out 8.75 volts so the battery is not charging. Could this be because there is a high resistance when I check the ground connection. (Neg battery post to chassy) I canot find where the main ground is located. I am aso looking to buy an owners manual/wireing schematic.
I also will be taking on the Onin propane generator, I've never seen one like this one lunger. Any assistace is welcomed. mossiyjack@gmailcom
Mossiyjack is offline   Reply With Quote
Old 09-19-2012, 02:01 AM   #2
shadeemry's Avatar
1975 31' Sovereign
cary , North Carolina
Check the breakers, then check continuity on every fuse, even if it looks good, they cab be broken behind the metal contact sleeve.
shadeemry is offline   Reply With Quote
Old 09-19-2012, 06:34 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Can't help with the univolt. However, I do have a 2.5kW propane-fueled Cummins/Onan generator, and I'll be glad to help if I can. What kind of help are you looking for?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-20-2012, 07:49 AM   #4
Mossiyjack's Avatar
1973 31' Sovereign
Cornville , Arizona
Thanks for the offer to help. The Onan is a small unit that was factory installed. In the process of bringing this trailer back to road worthy condition, I have had to remove the stove in order to get at the Univolt. It may be a while before taking on the generator because I've opened the gas line. Some preliminary inspection is my only option at this time. I am still looking on the internet for a wireing diagram/service manual. Happy Trails, JACK
Old 09-20-2012, 08:16 AM   #5
A reproduction of the owner's manual is available from the Airstream store, if you don't have a copy:
https://store.airstream.com/product_...roducts_id=384
A reproduction of the service manual (there was only one for the year, covering all trailer models) is also available from the Airstream Store:
https://store.airstream.com/product_...products_id=96
No idea whether it will have the specific information you need, though.
WBCCI #1105
TAC LA-4
Old 09-20-2012, 12:09 PM   #6
1988 32' Excella
Robbinsville , New Jersey
I believe the factory generator on your 73 is 12V only, just to charge the battery.
