01-15-2010, 11:31 AM
Princeton
, New Jersey
Univolt location in a 62
If anyone know the original location of a univolt in a 62 Airstream please advise.
Bob or Dave if you see this and have an answer please call me as we are remote to the net and a neighbor needs the answer.
Others please post and i hope we will get the answer before we part company with the Airstreamer that needs the answer.
2004 Excursion 4x4
01-15-2010, 03:20 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
62 ??
What model of a 62 is it?? Dave
01-15-2010, 03:33 PM
1968 24' Tradewind
1959 17' Pacer
holly springs
, Georgia
Hello
I think the first year for univolt was 64, before that 12v and 120 were separate.
Kevin
01-15-2010, 04:58 PM
1961 16' Bambi
Las Cruces
, New Mexico
hi
i've been about all over a '61 bambi. have yet to find a fuse panel for 12 volts or a univolt. there is a breaker box and polarity bulb for commercial electric. the tow vehicle cable goes inside the shell with no place to see the connections for what it powers. i'm slowly redoing the electric and have yet to find the old. i've left in the breaker box and polarity bulb for looks.
the new is starting to stand tall as it should be!
don
01-15-2010, 05:05 PM
Corona
Howie.
Univolts in any form, were not used until the 1964 models.
01-15-2010, 05:11 PM
Airstream Rescue
1948 22' Liner
1966 20' Globetrotter
Wimberley
Univolt
I believe the following is correct:
The first Univolt was introduced in 1964, but this was actually only a transfromer that transformed 120 Volt AC to 18 and 12 Volt AC. The first actual Univolt Converter that converted 120 Volt AC to 12 Volt DC was 1965.
Pat
01-15-2010, 06:35 PM
1977 27' Overlander
Naples
OK,how was the battery charged pre 64 ?? Dave
01-15-2010, 07:35 PM
1968 24' Tradewind
1959 17' Pacer
holly springs
, Georgia
Dave
pretty sure it was charged only by the TV. But in the case of dual voltage appliances there must be a transformer in the 120v line of the appliance.
Kevin
01-15-2010, 08:52 PM
1961 16' Bambi
Las Cruces
, New Mexico
hi
sorry to may have misled. with my '61 bambi i said the tow vehicle cable just disappears. should have said: leaves the tow vehicle, goes to a junction box on the side of the tongue, 4 wires come out, 2 for the battery charge which in my case used to be on the tongue, 2 for the break-a-way brake things, then the same size cable disappears. only thing left for it to do in 1961 was interior lights, running lights, and water pump. so simple that's it's a puzzler....
don
01-15-2010, 08:56 PM
Corona
The battery could be charged when hooked up to the tow vehicle.
But you could also hook up a "battery charger" to the battery, and watch it so it didn't overcharge.
That was it from Airstream production.
01-22-2010, 10:32 PM
New Borockton
, Alabama
How hard would it be to find the charge line and DC wires and connect them to a converter and a fuse board. I'm not up on the pre 64 model wiring but it does not sound too complicated to me.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
01-22-2010, 10:44 PM
1962 28' Ambassador
1962 30' Sovereign
Webster Groves
, Missouri
The fact that you have nothing but a few 12v fixtures + a battery, no fuses or access to wiring your really starting from scratch ...
01-22-2010, 10:56 PM
Retired.
, At Large
The charge line goes into an area under the belly pan, covered by a sheet of aluminum, usually on the right (curb) side of the trailer, near where the A-frame joins the frame. There is usually a self-resetting breaker there for the charge line.
I installed a converter under the kitchen counter next to the battery compartment, connected to several fuses, and replaced the self-resetting breakers in 3 spots in and under the trailer. I put a piece of clear Plexiglas over the fuse panel to keep metal kitchen utensils from shorting things out, and still tell at-a-glance if the fuses were blown.
01-22-2010, 10:59 PM
New Borockton
, Alabama
Bob are you too wiring a pre 64? Maybe you can help too. We are helping Howie find the wiring from where it exits and comes visable so we can see what we have to work with. Is it accessable in your unit? I'm figuring its a buried deep and curious if its accessible.
888-828-1893
Bestconverter.com
01-22-2010, 11:07 PM
Retired.
, At Large
Randy, see my post above. The charge line should be in a small area inside an aluminum cover on the belly pan. The charge line and battery lead should both be there.
Also, if you want a battery to fit that compartment under the window, it should be a 2EE or 3EE.
01-22-2010, 11:13 PM
1962 28' Ambassador
1962 30' Sovereign
Webster Groves
, Missouri
Thats just the thing ... The TV +12v goes to the battery + and the battery + then fans out inside the skin ... looping fixture to fixture ... no fuse no nuttin'.
The umbilical wire nuts to the wiring runs inside the front panel just inside of the street side seam right above the floor. One of my 62s had a hole cut on the inside panel under the gaucho to effect repairs ... careful you don't cut wires when you cut the panel.
01-22-2010, 11:16 PM
1962 28' Ambassador
1962 30' Sovereign
Webster Groves
, Missouri
I'll look again but don't remember covers on either one of mine ...
01-22-2010, 11:21 PM
New Borockton
, Alabama
I learned something. I don't have a pre 64, thanks and I see Terry has the answer. Good work Terry!
888-828-1893
Bestconverter.com
01-22-2010, 11:25 PM
1962 28' Ambassador
1962 30' Sovereign
Webster Groves
, Missouri
Yeah, yeah! ... You Overlanders stick together ...
