Old 01-22-2010, 11:07 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by 68 Overlander View Post
Bob are you too wiring a pre 64? Maybe you can help too. We are helping Howie find the wiring from where it exits and comes visable so we can see what we have to work with. Is it accessable in your unit? I'm figuring its a buried deep and curious if its accessible.
Randy, see my post above. The charge line should be in a small area inside an aluminum cover on the belly pan. The charge line and battery lead should both be there.
Also, if you want a battery to fit that compartment under the window, it should be a 2EE or 3EE.
Old 01-22-2010, 11:13 PM   #16
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Thats just the thing ... The TV +12v goes to the battery + and the battery + then fans out inside the skin ... looping fixture to fixture ... no fuse no nuttin'.
The umbilical wire nuts to the wiring runs inside the front panel just inside of the street side seam right above the floor. One of my 62s had a hole cut on the inside panel under the gaucho to effect repairs ... careful you don't cut wires when you cut the panel.
Xbob2 is offline   Reply With Quote
Old 01-22-2010, 11:16 PM   #17
1962 28' Ambassador
1962 30' Sovereign
I'll look again but don't remember covers on either one of mine ...
Old 01-22-2010, 11:21 PM   #18
New Borockton , Alabama
Images: 21
I learned something. I don't have a pre 64, thanks and I see Terry has the answer. Good work Terry!
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 01-22-2010, 11:25 PM   #19
1962 28' Ambassador
1962 30' Sovereign
Yeah, yeah! ... You Overlanders stick together ...
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
new a/c location ? twiggy137 Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-06-2008 07:55 PM
Univolt Location guy99 Mechanics Corner - Engines, Transmission & More... 20 07-07-2005 10:31 PM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
