01-10-2010, 10:48 PM
Maniacal Engineer
Lopez Island
Univolt internals - which fuse is which?
Hi folks -
I spent some time this weekend examing the electrical systems on our new (to us) 1971 Tradewind. Most everything works when I hook up the 120VAC line, but there's no juice w/ just the batteries. A couple of the fuses in the Univolt IV blue box were obviously bad, but replacing them doesn't help. Others may need replacing as well; I've not yet checked each one.
I cannot read the piece of paper on the inside of the Univolt that supposedly explains which fuse does what - does anyone have a photo or scan of the original manual? There's probably a converter in my future - and we're definitely moving the dual 12V batteries the PO had loose under the bed(!) - but right now I'd like get things figured out w/ the existing system.
- Bart
01-11-2010, 05:03 AM
1965 22' Safari
Vassar
, Michigan
Univolt
Bart,
Check the main fuse (small) next to the two screw-in fuses on the univolt. Batteries under bed may have something to do with keeping them warm in cold weather. Battery charge drops off when cold......Tim
My be that my univolt is an older style than yours.
Tim
TAC MI 14
Everyday is a Saturday
01-11-2010, 05:11 AM
2002 25' Safari
Dewey
This is the 12 volt distribution used in my 75 Trade Wind. It sows the connection from the battery as well as all the circuts to the trailer.
Hope that this helps.
Richard
01-11-2010, 07:36 AM
1993 34' Excella
Estancia
, New Mexico
I don't remember any "screw in fuses" on the 71 Univolt. Note there are 2 or 3 40 amp fuses. The one for the trailer battery is the one I would start with. The 40 amp fuses are very hard to find. There are several different configurations in 70s Univolts. 40 amp fuses are in both large and smaller sizes. I use a 40 amp resetting circuit breaker that fits into the fuse holder. A photo of your fuse panel would help.
01-11-2010, 07:48 AM
Corona
Originally Posted by tkasten
Bart,
The 1965 Airstreams, except for the Caravelle's used a battery charger called a "Constavolt".
It indeed had a couple of screw in fuses.
It was also very large in size, but Airstream buried it under the bathroom closet.
I am amazed that someone still had one, especially one that's still working.
That just proves, that everything old, is not always bad.
01-11-2010, 09:52 PM
Maniacal Engineer
Lopez Island
So I've mostly puzzled this out w/ the diagram posted by azflycaster. Here's a photo; youi can see the fried battery fuse. The only one I'm still figuring out is the lowest fuse on the left, but that just needs some experimenting.
Thanks for the help!
- Bart
05-24-2010, 07:25 PM
1971 18' Caravel
St Augustine
Did you ever discover what the lower left fuse went to? The reason I ask is I have the same Univolt and I get continuity to the battery with every fuse except the lower left.
05-24-2010, 09:18 PM
Corona
That fuse is for the remote ammeter.
05-26-2010, 06:57 PM
Shady Side
, Maryland
I have a simalir problem. My univolt wont power up unless i jump the bottom two fuses together. What could my problem be??
08-13-2017, 09:18 AM
1966 26' Overlander
Woodstock
, Georgia
Ok so which fuses are 30 or 40 amp? I don't see them. Do I need to take the cover off the Univolt...under the closet? It works fine but just recently blew a fuse somewhere...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Univolt and Fuse Panel - Can Somebody take a Pic?
mello mike |
Electrical - Systems, Generators, Batteries & Solar |
11 |
06-30-2009 10:16 AM |
old univolt fuse panel new parallax7400
csaweeks |
6 |
04-19-2009 08:00 AM |
Removing fuse panel from Univolt
pintoman |
Batteries, Univolts, Converters & Inverters |
7 |
05-11-2008 12:31 PM |
fuse help !!!!
Shellie |
3 |
05-17-2006 06:24 PM |
Fuse size?
working |
5 |
05-08-2003 10:11 PM |
