Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 07-31-2006, 10:56 AM   #1
mtnman
Profile:  Currently Looking...
Collettsville , North Carolina
univolt help
Hello all,
I notice that my battery was taking a long time to re-charge and checked the univolt on my 1979 argosy. The univolt is only putting out 11 volts.
Is the univolt adjustable?
What should the univolt be putting out (volts)?
How many amps does the unvolt charge at?
Should I replace the univolt?
What replacement options are there?
mtnman
mtnman is offline   Reply With Quote
Old 07-31-2006, 11:44 AM   #2
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Originally Posted by mtnman
Hello all,
The univolt is only putting out 11 volts. BAD
Is the univolt adjustable? Not Manually, maybe not at all
What should the univolt be putting out (volts)? Depends upon manufacturer, but usually around 13.6volts, DC
How many amps does the unvolt charge at? That is dependant upon the actual Univolt or charger that is sitting there. They come in 30, 45, 60 and higher current outputs, but each converter is built to a certain capacity. You would use about 45 amps, unless you are running a lot of extra equipment from your battery.
Should I replace the univolt? Yes. Your's is done.
What replacement options are there? OEM from Inland RV, Intellipower, WFCO and IOTA cover about 99% of all converter replacements discussed on this forum. I have an IOTA and love it.
mtnman
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 07-31-2006, 12:07 PM   #3
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Are you sure it's the Univolt and not a bad battery? If you've got a bad cell the voltage will only ever com up to 11 volts. One of the floating bulb battery testers will tell you if you have a bad cell; assuming it's a standard lead plate electrolyte battery. Otherwise you'll have to try charging it some other way. What voltate does it come up to aafter towing for a while?
-Bernie
bhayden is offline   Reply With Quote
Old 07-31-2006, 12:17 PM   #4
mtnman
Yes, its a new battery
What voltage does it come up to after towing for a while?
12.75 Volts from the meter after towing a ways.
mtnman
Old 07-31-2006, 12:37 PM   #5
mtnman
AYRSTRM2,
45 amps sounds like a lot for a 1979 Argosy but if it will work thats what I want. I guess its nothing more than a better battery charger? Any certain place I can shop for this converter?
Thanks again,
mtnman
Old 07-31-2006, 12:45 PM   #6
mtnman
Will this work?
Brand new Iota DLS-55 12V Power Converter and Battery charger.
55 Amp Converter
740 Watt Power Output
Dual Voltage Jack for 2-stage Charging
Weight: 5.5 lbs
Dimensions: 7” x 6.5” x 3.5” Includes the 110 power cord
mtnman
Old 07-31-2006, 12:49 PM   #7
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Take a look at the converters at: http://www.bestconverter.com/
They are forum friendly!
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-31-2006, 01:07 PM   #8
AYRSTRM2
AYRSTRM2's Avatar
Armada , Michigan
It most certainly will. Bestconverter.com also has good converter/chargers. Look them over and take you pick.
JOHN
Will this work?
55 Amp Converter
Weight: 5.5 lbs
mtnman
John
Old 03-23-2007, 09:25 AM   #9
raebaker06
Profile:  Burlington , Ontario
The Univolt that I have is really a 6.0 volt transformer with diodes and a ciruit that is a Voltage Doubler.
i would check the 1.0 microfarad AC capacitor, (you can get one from a electric motor repair shop Mine cost 4.95.
If it is leaky it will not help raise the voltage sufficiently. They are oil filled and do dry out
Raebaker@comcast.net
raebaker06 is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
