Old 05-09-2004, 06:07 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Univolt????help
Hello, I am having a problem with my 12 volt and don't know if it might be the univolt. All of the fuses have 12.2 volts and nothing works, when I plug into 110 everything works and the univolt hums and the battery reads 12.3 volts. What is wrong? Thaks for your help. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-09-2004, 06:59 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
marvin
there may be one more fuse you are overlooking.
the negitive lead has a fuse also.
you may want to remove the fuses and use your volt meter set to "ohms" or the omega symbol and check for zero ohms on each fuse.
that way you can be 100 percent sure it is something else!
john
you call them ferrets, i call them weasels.
Old 05-09-2004, 07:02 PM   #3
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Marvin,
Make sure your negative battery cable is not full of corrosion.... run a new ground to test with such as a jumper cable on negative (-battery) to chassis.
jjonesnc is offline   Reply With Quote
Old 05-09-2004, 09:02 PM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Check your battery..it should read higher than that if it's properly charged.`
btw, just what kind of battery do you have?? I hope not an "Auto" battery`!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-10-2004, 03:50 AM   #5
jjonesnc's Avatar
Images: 8
Also make sure the battery has water in it
Old 05-10-2004, 05:01 AM   #6
1979 30' Argosy
Re battery
Hello.. The battery is a group 72 marvin rv interstate . It is full of water and usually charged to 12.4.. Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-10-2004, 05:02 AM   #7
1979 30' Argosy
Re battery..
This is early am and made a mistake .. it is a marine rv battery.. Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-10-2004, 11:41 AM   #8
1979 30' Argosy
Hi, I found the problem this morning, the ground had been spliced way behind the oven and it was corroded badly. Everything works great now. Thanks ot everyone for all the help. Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
