Old 06-16-2010, 04:29 PM   #1
1978 28' Ambassador
Savannah , Georgia
Univolt for Dummies..or Dummy
First got AS and light on control panel for AC power came on and now is off. Assumed it was a blown LED. Have been hooked up to 110v. Not really used 12 volt pump or lights. Used both last week and noticed lights got dimmer and pump worked slowly. Opened fuse box and checked all fuses. Other than some corrosion on contacts everything looked good. Today uncovered univolt and checked 110 outlet. Noticed univolt humming "quietly". Tonight will disconnect 110 plug to AS and run lights. Then plug in 110 and see if lights get brighter. Have a voltmeter, but not real sure how to use it on battery. Battery less than five months old. Doubt pictures will help, but more than willing to provide any needed shots. How to procede? Future plans are to put AS at a campground connected to power and water. Will use 12v for lights and maybe furnance. Thanks for any help. Jack
Skamper1 is offline   Reply With Quote
Old 06-16-2010, 06:04 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Univolts hum...that is a given. If you are plugged in you should get your full 12 volts at your lights and furnace. Depending on the year the Univolt may over charge the battery if plugged in full time. I usually cycle mine by unplugging the trailer for a period of time. I would consider an upgrade to one of the newer solid state chargers like the Xantrex.
Aaron
WBCCI #XXXX AIR #2495
Old 06-16-2010, 08:01 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Call Randy at Bestconverters.com, if you want a new converter. I just go my new IOTA, based on Randy's recommendation, converter today. It is 1/3 the size and weight of the old Univolt and has smart charge option so I won't cook my batteries.
Old 06-16-2010, 09:23 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Skamper1
If your AC power light went off and your batteries seem to be going down, it sound like you may not be connected to AC power or the breaker has tripped. Plug an appliance into one of the outlets to see if you have AC power.
The recommendation to just go ahead and replace the univolt is a no brainer. It will cost you around $200 and is very easy to do.
Dan
TouringDan is online now   Reply With Quote
Old 06-17-2010, 05:29 AM   #5
1978 28' Ambassador
Savannah , Georgia
Think decision has been made. Battery is dead. Lights did not brighten when restored shore power. Did check 110 connection at the outlet where univolt is plugged. See where there is a 55 amp univolt on sale. Can I just remove the old unit and replace with the 55 amp? Thanks. Jack
Windows for dummies help... Skamper1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 04-26-2010 03:40 PM
1948 AS Help a dummy out! scarylarry Title, VIN & Registration 3 05-07-2009 07:39 AM
Need electricity for dummy intro Pudentane Batteries, Univolts, Converters & Inverters 4 08-17-2008 05:49 PM
Electrical Dummy Wardinbb Electrical - Systems, Generators, Batteries & Solar 70 01-08-2006 07:29 PM
My husband, Mr. Dummy.... (Found this on eBay) BobbyW Our Community 19 05-13-2004 06:24 AM
