Old 06-28-2002, 11:42 AM   #1
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Univolt/Dual Batteries
Does anyone know if the Univolt would support dual Batteries simply wired in parallel? Or must one use an isolator or switch in order to use 2 batteries?
Our battery lasts through about 2 nights, with lights for reading etc. But then there is the water pump etc.......
Also, my tow vehicle does not currently have a 12V charge circuit at the trailer connector hooked up. Is this simply a heavy wire coming from the vehicle battery or does it need a dual battery device n the tow vehicle?
Any experiences shared with me would be appreciated!
Ciao,
Uwe
Old 06-28-2002, 02:55 PM   #2
Univolt charging
The Univolt is a converter.. It is able to charge one or 10 batteries at the same time providing all the positive posts are connected together and all the negative posts are connected. The more batteries connected the longer the charge time. The Univolt will only charge a battery if there is 120volts ac available. Converters come with many 12volt dc outputs. The output is from 20 thru 95 amps.
If possible to create a tow vehicle charge line, do it today. Wire the power on a seperate fuse of about 30 amps, thru a relay that is controlled by the ignition circuit and use #10 mtw stranded wire with soldered connections. Time and energy expended upon initial fabrication will pay great dividends later When the engine is at rest, the trailer can not draw any power from tow vehicle's battery. This is a good time for a dash volt meter....
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 06-28-2002, 03:36 PM   #3
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Univolt/Batteries
I happen to have rear A/C and Heat in my tow vehicle, which means there are already wiring provisions to which I can attach the wire from the battery. I will do this before our next trip and after I figure out the A&E awning problem.
Thank you for the advice.
Uwe
Old 06-28-2002, 04:09 PM   #4
I'm confused
There is no relationship between rear ac and heat with a charging circuit for trailer batteries.... The charge line should be for very specific purpose...
Old 06-28-2002, 08:26 PM   #5
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
not to be confused
I meant that here are already wiring channels going from the engine compartment to the very rear of the van, which can be used to include the charging cable for the trailer.
Uwe
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
Coach Batteries AccessMaster Airstream Motorhome Forums 20 03-23-2004 08:40 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
