Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 06-22-2007, 07:26 AM   #1
Profile:  1974 25' Tradewind
Muscle Shoals , Alabama
Univolt charging
How can I tell if my univolt is adequately charging my battery?
chuman70 is offline   Reply With Quote
Old 06-22-2007, 08:43 AM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Airstream Registry
Voltage should be 13.8 VDC. Lower will under chagre. over will cook the battery. You will hear this many times. Throw the Univolt away. Get a modern three stage charger.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 06-22-2007, 09:09 AM   #3
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Check the charge at the battery
Use a volt meter to see what the battery voltage is charging at! It is best if it holds around 13.8 VDC. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-22-2007, 09:41 AM   #4
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Mine was holding steady @13.83, so at least I got that going for me.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
