Old 12-02-2009, 06:37 PM   #1
1969 27' Overlander
Hernando , Florida
Univolt buzzes then stops
I am brand new to Airstream having just purchased a 1969 overlander in great shape for its age.
THe problem is the Univolt, when plugged into shore power, it buzz's for about 5 to 7 seconds then you hear a boing''''' like a cartoon spring. it seems to recycle, buzz then boing'''' again. This goes on until I unplug the unit.
When we first brought it home it seemed to work fine after I put the battery in. The next day this buzz/boing''' started.
YOur help is greatly apprecaited
JoeMahippah is offline   Reply With Quote
Old 12-02-2009, 06:51 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
That sounds like a circuit breaker popping. Better start checking for a short. Battery reversed? Something touching metal?
Bigventure is offline   Reply With Quote
Old 12-02-2009, 06:57 PM   #3
1969 27' Overlander
Hernando , Florida
The noise all comes from the univolt. THe unit is on the left side in an outside compartment and the 4 circuit breaker panel is on the right side in the bathroom. I have checked the breakers and none are popped.
Old 12-02-2009, 09:14 PM   #4
There is built in breaker within the univolt.
Disconnect 1/2 of the circuits, and see what happens.
If the "boing" continues, then reconnect the disconnected circuit, and disconnect the other circuits.
If the "boing" still continues, disconnect all the circuits and see what happens.
You more than likely have a short in a circuit. The idea is to isolate it and once you know which circuit has the problem, you can start chasing that down. Or make a post and state which circuit is bad.
Some of us can help you with tracing the problem down.
Old 12-03-2009, 07:06 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Many owners have decided to upgrade from Univolts to modern 3 stage converters. The main reason is 3 stage converters do a better job, and the Univolts can damage batteries. You might want to consider this at some point. There is plenty of information in the forums archives if you do a search.
Old 12-03-2009, 08:12 AM   #6
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Andy has a good trouble shooting checklist, but I recommend that you save yourself a few minutes and disconnect all the circuts as the first step. I'm betting it's the Univolt itself. If it isn't, use Andy's method of resolve the problem.
However, even if you do resolve it to a circut, the Univolt will still be buzzing. Replace it per Lumatic's suggestion. The new unit, what ever you buy, will wiegh less than 1/4 of the Univolt and your batteries will last more than twice as long. It's a good investment.
Old Univolts aren't totally useless. If it's still putting out 14 Volts (its voltage regulation is poor without a battery hooked to it) or so, keep it in the shop to supply 12V for testing other components, like pumps, etc.
Zep
Old 12-03-2009, 06:02 PM   #7
1969 27' Overlander
Hernando , Florida
I will start testing tomorrow. THe more I play, the more I know. Thanks Andy. I will also check with my local RV guys on an upgrade. I like to buy local, it keeps local guys in business.
Thank You
Old 12-04-2009, 12:03 AM   #8
New Borockton , Alabama
Images: 21
Hi Joe,
I promise I can help you, its a no brainer. If you have a Univolt made in in 1969, you can play with it for fun but we have all been there and to waste time with it is well, a waste of time unless you are trying to preserve it. You are less then $200 away from having a perfect DC power supply and the number one upgrade to any older RV.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
And the fun never stops Gunnyusmc 2006 Safari SE 123 04-20-2009 12:56 PM
Rest Stops janetb On The Road... 16 11-22-2007 08:37 AM
Rest Stops Minnie's Mate On The Road... 32 02-13-2007 07:26 PM
5,999 and he stops?!? mistral blue Off Topic Forum 21 01-12-2007 05:55 PM
RV (Truck) Stops 74Argosy24MH Link Archive 5 10-28-2002 05:24 AM
