Old 03-22-2009, 06:45 PM   #1
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Univolt AND an IOTA on board???
Hi all:
The PO of my '74 Overlander proudly showed us the new inverter/charger that he put in the camper shortly before we bought it. At the time, this being our first camper that wasn't a tent, I thought this was great. Well, I noticed the other day that the interior lights were very dim. More so than in the past. The trailer has been plugged into the house since the day we brought her home. I checked the battery (Optima blue top) and the voltage was down to 7.6. OK, so I have a problem. I took the battery out, put in on the trusty battery charger in the garage, attached the volt meter and walked away. I came back and it was taking a charge. I left it sitting on my workbench off the charger over the weekend and I just checked it again and it was still around 12 volts, so the battery isn't trashed. So, I took off the panel for access to the inverter/charger. I think I found the problem...a loose output wire on the IOTA converter/changer. Nevertheless, I was surprised to see the Univolt V still there. I thought that there wouldn't be a need for both??? Nevertheless, the output wires from the IOTA disappear inside the Univolt. The actual wires that connect to the battery via the plug lead into the Univolt as well. Am I crazy or is this messed up? Shouldn't the IOTA REPLACE the Univolt, not be an add-on? The only advantage that I can see to this would be that with the Univolt in place then the charge indicator on the info panel in the camper would still show the battery charge. I checked all fuses in the Univolt and the IOTA, plus the master fuse. Everything is good.
Now the question: Do I remove the Univolt? What the heck do I do with all the extra wires? The IOTA seems simple enough...plug in to A/C, two wires out. There's a heck of a lot more wires than that into and out of the Univolt.
Name:	IMG_1882 (Large).JPG
Name:	IMG_1883 (Large).JPG
Name:	IMG_1884 (Large).JPG
Name:	IMG_1885 (Large).JPG
WineStream is offline   Reply With Quote
Old 03-22-2009, 07:02 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The PO could have removed the 12 volt distribution panel from the Univolt and wired the new converter to the panel. Instead it sounds like he left the Univolt in the trailer and wired the new converter into the attached panel. You can clean this up and remove some weight at the same time.
Richard
Old 03-22-2009, 07:32 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My Unintellipower
A 9245 fits nicely on the back end of the old Univolt allowing the use of the old fuse panel. It's a simple matter to connect the two.
Old 03-23-2009, 06:15 PM   #4
WineStream's Avatar
2005 30' Safari
Images: 24
Wow, that's a great setup. I pulled at my Univolt a bit and discovered that it has had its guts removed, although the complete shell is still there. I reconnected the IOTA a bit better, checked everything for function, and all seems to be OK. When I have more time and it's warmer outside, I will redo things a bit nicer like Lumatic.
New to the Board!!! petsmo Off Topic Forum 9 11-02-2005 06:01 PM
Iota converter mandolindave Electrical - Systems, Generators, Batteries & Solar 2 07-06-2005 09:26 PM
New on board Big Blue Our Community 11 05-21-2005 08:36 AM
RV Board Tin Hut Our Community 2 06-15-2004 06:34 PM
