Old 04-22-2012, 05:46 PM   #1
1978 Argosy 27
Hoover , Alabama
Univolt
Just pulled the univolt from the TT. Man it's heavier than I thought...
I plan to run the electrical system via a Honda generator or though direct hookups. No battery. No solar.
Is there any need to replace the univolt?
C
cford is offline   Reply With Quote
Old 04-22-2012, 05:49 PM   #2
Gainesville , Florida
What about 12 volt? Water pump , lights, etc are 12 volt, I think---you need a converter. Am I wrong? jim
Old 04-22-2012, 05:51 PM   #3
1978 Argosy 27
Hoover , Alabama
I do not know.
Do I need a converter to protect the 12 volt electrical system from overload though the generator or 30 amp connection?
I am guessing it do but need some insight.
C
Old 04-22-2012, 05:55 PM   #4
I believe your gen and hookups are both 120 volt. Without a converter you would have no 12 volt. jim
Old 04-22-2012, 06:01 PM   #5
1978 Argosy 27
Hoover , Alabama
Dumb question...
Does that mean my lights would not works when not plugged up to connections because I have no battery?
Old 04-22-2012, 06:06 PM   #6
yes,jim
Old 04-22-2012, 06:10 PM   #7
Also I do not think your breakaway switch will work. That is a legal thing. Might not have any lights outside trailer either, tail, brake, etc. jim
Old 04-22-2012, 06:10 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes you will need a converter for all 12v.... interior and exterior lights, vent and furnace fans, water pump, fridge, water heater and furnace electrics.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-22-2012, 06:10 PM   #9
1978 Argosy 27
Hoover , Alabama
yes,jim
If I am plugged into service, generator or a thirty amp...
Without the converter, do the lights work? And if the do, I'm I running the risk of burning up the wiring without the converter?
Thank you for answer my dumb questions
C
Old 04-22-2012, 06:14 PM   #10
2005 19' Safari
GLENDALE , AZ
I think that you could hook up one set of battery cables to the 12 volt DC terminals on the generator. However, I believe that Honda says that the 12 volt output is unregulated, so the exact voltage may vary with load.
Please note that I have not heard of anyone that has done this before. Usually, the 12 volt connection is used to tie two Hondas together to double their AC output.
Good point made above, that the break away switch wouldn't work. That might make this an unsafe modification.
Old 04-22-2012, 06:29 PM   #11
That might work but it would only be 8 amps I think.. Maybe you could plug a good battery charger into the gen and hook it to your battery cables. Better wait for the experts to chime in. jim
Old 04-22-2012, 06:33 PM   #12
Thumbs up
cford,
Give Randy a call, he will point you in the right direction.
PFC
"Tahawus"
RLC
John Prine
Old 04-22-2012, 06:45 PM   #13
1978 Argosy 27
Hoover , Alabama
Originally Posted by ROBERT CROSS
cford,
Will do..
Thanks to all
Old 04-22-2012, 07:34 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You only need the battery for the breakaway switch when traveling. If you have a converter it will provide the 12 volt power for all of the 12 volt devices. The battery is not necessary if you are not towing the trailer and are plugged in to shore power.
The battery in the trailer has nothing to do with the tail, brake, turn signals or marker lights. All of that as well as brake and charge line power come from the TV.
TG Twinkie is online now   Reply With Quote
