Old 02-22-2013, 03:29 PM   #1
scooterbug76's Avatar
1969 27' Overlander
Northeast , Georgia
Univolt 45 amp converter to a 30 amp converter
Are we asking for problems if we change out our Univolt 45 amp converter to a 30 amp converter? By the way, we would be doing this on a 69 Overlander Land Yaucht.
scooterbug76 is offline   Reply With Quote
Old 02-22-2013, 03:33 PM   #2
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Why not just get a new 45amp converter rather than a 30?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 02-22-2013, 03:39 PM   #3
1969 27' Overlander
Northeast , Georgia
Well we have a 30 amp that was given to us for free.
Old 02-22-2013, 04:20 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I doubt it would make any difference, except posibly a little slower charge if hooked to a dead battery. The normal 12 volt load, lights furnace, pump etc won't approach 30 amps.
If I already had the unit I would use it
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-22-2013, 04:35 PM   #5
Kevin245's Avatar
Free is good. 30 Amps should work. I would use it.
Eleanor Roosevelt
Old 02-22-2013, 04:40 PM   #6
1969 27' Overlander
Northeast , Georgia
The 30 amp is hooked up temporarily. It does have a little buzzing sound...is that normal?
Old 02-22-2013, 04:55 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is it another Univolt? If so it will hum. Because it doesn't know the words.LOL
If not a Univolt. What is it?
TG Twinkie is online now   Reply With Quote
Old 02-22-2013, 10:11 PM   #8
ddruker's Avatar
2000 27' Safari
Palo Alto , California
Some of them buzz. Not generally a problem. As to 45 Amp vs. 30 Amp - it's unlikely you will put more than a 30 Amp 12V load on your trailer - that's 360 watts - so the only impact you are likely to see is slower battery charging...
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
Old 02-23-2013, 08:52 AM   #9
1988 32' Excella
Robbinsville , New Jersey
As others have said 30 amp should not be a problem, even if you draw more then 30 amp, if you have a battery it doesn't matter. It will only be a problem if you exceed the converters capacity enough to drain the battery.
A little secret most people exceed their converters capacity. After all on these converters the capacity is 0 amps when they are not getting 120V.
I went through 1 season with a 10 amp battery charger and since it hummed I hooked it to a timer so that it shutoff at night and came on in the morning since 10 amps was way more then I needed on average.
Old 02-23-2013, 10:32 AM   #10
ddruker's Avatar
2000 27' Safari
Wazbro is right - that was stupid of me to imply that you can't also draw from your battery while your converter is turned on.
- Dan
Old 02-23-2013, 11:43 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't think you draw from your battery while the converter is connected to shore power. The reason I say that is. All of the 12 volt devices will work without the battery if you are plugged into shore power.
I remove the battery when my trailer is stored. It is connected to shore power and all DC systems work just fine.
Old 02-23-2013, 11:56 AM   #12
1988 32' Excella
I don't believe it's 100% true that you do or don't draw 12V from the battery when your plugged in. If you plugged in and have your battery connected (more so for older converters) the battery acts as a buffer to stabilize the voltage, slight draw from battery to absorb a surge when something first comes on till the converter increases output and if the load goes above the output of the converter for a sort time.
Old 02-23-2013, 12:42 PM   #13
ddruker's Avatar
2000 27' Safari
Think of it this way -
That 30 amp converter will put out roughly 360 watts (30 amps * 12 volts) of power - for as long as it is plugged in to line voltage.
Your battery is connected in parallel to the converter. It can put out many more watts than 360 at any instant - but only until it is depleted.
The two of them work together to provide power to your 12V system. You can run your 12V devices on the converter alone if you disconnect the battery, or the battery alone if you disconnect your converter, or both if they are both connected. The inverter will also charge the battery while both are connected and the inverter is plugged into AC power.
For giggles, say you connected 500 watts worth of devices to your 12V system and turned them all on. Your converter could power the first 360 watts worth of load. You battery would provide additional power for the remaining 140 watts - and it would keep doing this until it was depleted. Once you turned off enough devices to reduce the load back to below 360 watts, your converter would have enough surplus capacity to start charging your battery again.
Make sense?
- Dan
Old 02-23-2013, 04:17 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't think so. If the converter reaches it's max capacity or exceeds it. It will shut down on overload. Or fail all together.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
30 amp to 50 amp ALANSD Electrical - Systems, Generators, Batteries & Solar 7 10-13-2011 04:59 PM
Converter Question henw Batteries, Univolts, Converters & Inverters 5 05-10-2011 06:55 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
