Old 02-24-2013, 01:40 PM   #15
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Aren't they fused to avoid overload? Thanks for the in depth explanations, trying to understand the Airstream electrical system, charging/12/120v, makes my head hurt.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 02-24-2013, 02:59 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have a Progressive Dynamics converter for example. There are fuses (2) which are there to protect the unit if it is connected with the wrong polarity. Not to protect it from an overload. The large fuses in your fuse panel are there for the protection of the wire between the converter and the fuse panel.
Back in the last century, there were battery chargers that were literally small welding machines. These devices would literally destroy themselves if shorted for an excessive period of time. With the advent of intelligent design of the modern charging equipment. These devices will protect themselves by limiting the output current. The less expensive devices just "crowbar" shut down the output until the overload is removed. Others simply limit the current that is available.
This is the reason I always recommend using a modern battery charger when troubleshooting the 12 volt DC systems on a trailer. Instead of using a battery. I don't recommend do this in any way. But if you were to connect a wire across the + and - terminals of a battery. The wire would turn red hot and melt instantaneously or worse yet, the battery may explode. You can do a lot of damage to the wiring in the trailer by using a battery that is not wired thru the correct protective device, either a fuse or 12 volt circuit breaker.
Probably more than you wanted or needed to know.
TG Twinkie is online now   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
30 amp to 50 amp ALANSD Electrical - Systems, Generators, Batteries & Solar 7 10-13-2011 04:59 PM
Converter Question henw Batteries, Univolts, Converters & Inverters 5 05-10-2011 06:55 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
