Old 01-10-2015, 12:52 PM   #1
1983 31' Excella
Chehalis , Washington
Univolt??
I recently purchased a 1983 Excella and cannot get the AC power to work. I can hear the humming when plugged into the AC power. I can't find where the inverter is. Does anyone know..
Roothang is offline   Reply With Quote
Old 01-10-2015, 01:22 PM   #2
1987 25' Sovereign
Oregon , Ohio
We have a 1987 Sovereign and ours is under the couch at the front of the trailer. Do you mean a converter charger instead of an inverter.
msmcv51 is offline   Reply With Quote
Old 01-10-2015, 01:28 PM   #3
New Borockton , Alabama
Images: 21
Often the Univolt is behind the gaucho. The older ones do hum. The fact that you can hear it humming suggest that you are getting ac power to at least that circuit.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 01-10-2015, 02:26 PM   #4
1983 31' Excella
Not sure if it is called a univolt or converter.
p401668 is offline   Reply With Quote
Old 01-10-2015, 06:33 PM   #5
Images: 21
Same thing p4. Several companies made the Univolt for Airstream over the years but its still a DC power supply (converter)
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Univolt Configuration rslaymaker Electrical - Systems, Generators, Batteries & Solar 32 02-26-2006 06:50 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
"univolt" Chuck Electrical - Systems, Generators, Batteries & Solar 10 06-07-2002 01:30 PM
