Old 10-28-2015, 12:32 PM   #1
1965 22' Safari
Point , NW
Univolt/12
Thought I would pass along a little lesson I learned today to perhaps save some time when trouble shooting electrical problems. My son and I went bird hunting in Montana, first night out, dry camping, half the lights, furnace, water pump and overhead fan would not work on battery power. Reading lights worked fine. We hooked up the generator and all the above worked fine. I figured a short or broken power or ground wire somewhere in two of the 12 volt circuits which I would trouble shoot when home. But why would everything work when plugged into 120v power but not on battery alone?
Got home and started testing all circuits, two did not have power with battery, although they did with shore power. I measured the battery and discovered it was not charging when plugged into shore power. So short version, I finally took the cover off the Univolt and found one of the two old type 120 volt round screw in fuses was loose, couldn't possible be that easy! Yes, that was the problem, everything now works on battery and/or shore power. So why do 2 of the 12 volt circuits depend on the 120 volt fuse in the Univolt? I thought the 12 volt and 120 volt would be totally independent.
I had installed a propane cat heater before leaving and it kept us warm without the use of the battery.
Sburg58 is offline   Reply With Quote
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Univolt Configuration rslaymaker Electrical - Systems, Generators, Batteries & Solar 32 02-26-2006 06:50 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
"univolt" Chuck Electrical - Systems, Generators, Batteries & Solar 10 06-07-2002 01:30 PM
