Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 02-28-2008, 03:27 PM   #1
max7
max7's Avatar
Profile:  1965 20' Globetrotter
1966 22' Safari
Apple , California
Two wire and three wire converters???
Got a question, I am going to replace the Triad-Ultrad TV 750-2 Converter Charger in my 65' Globetrotter with a Progressive Dynamics, Inc. Inteli-Power 9245 Converter with charge wizard. This converter will be an easy swap It has two wires Red + and White - ....fine.
Here is my question: I would like to install the Triad-Ultrad in My 66' Safari because it does not have a converter. BUT, the Safari has three wires Red, White, and Black. How can I hook the two wire Triad-Ultrad up safely? Leave some thing disconnected?
Here is a pic of my 66' Safari wiring:
Thanks!
max7 is offline   Reply With Quote
Old 02-28-2008, 06:27 PM   #2
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
When I removed my old converter in the '77 Safari, I notice it had three wires. On close inspection, two were 12v and one was ground. The two 12v wires differed in that one was highly filtered (good quality) but lower current, the other was crappy DC but higher current. Presumably the good quality circuit was for the radio/8-track player.
In some converters the 12v output is divided, one leg for battery charging, the other for trailer circuits.
Either way, to hook up your two wire converter, you need to figure out which of those three wires are for 12v and hook both of them together to the 12v output of the converter. Just be sure they are both for 12v. One of them may be the charge line from the tow vehicle, which is OK.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Wire Size Help tkendall Batteries, Univolts, Converters & Inverters 2 04-13-2008 12:44 PM
What's this do? Battery wire Goin camping Batteries, Univolts, Converters & Inverters 13 12-13-2006 09:45 AM
This wire doesn't look right? LI Pets Electrical - Systems, Generators, Batteries & Solar 10 09-02-2006 08:37 AM
loose wire whistler Electrical - Systems, Generators, Batteries & Solar 6 02-21-2004 04:50 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
