Old 11-08-2015, 07:08 AM   #29
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by BoldAdventure View Post
My question was for KJRitchie, I have a twin too. Curious about his final placement, and length of cables used, etc.
Looks like our twin bed conversion will not start until after the new year. The shop has too much scheduled work this time of year.
Lithiums would be nice but they are way outside of our budget.
I read somewhere someone stating Trojan AGMs need to be vented. Is that true?
Kelvin
Old 11-08-2015, 11:23 AM   #30
lewster's Avatar
Naples, FL , Hood River, OR
Kelvin
Technically, (especially if you ask the battery makers) ALL lead acid batteries should be vented. Since the only lead based batteries that I use are Lifeline AGMs, my comments will relate to them specifically.
All Lifeline AGMs recombined any gasses created during the charging process back into the glass mat material. In the unlikely scenario of severe over charging (above 15.5VDC at 77 deg. F) or thermal runaway, the one way safety vent in each Lifeline will open and expel excess hydrogen sulfide gas.
This also decreases the amount of moisture within the battery, changing the chemical makeup and essentially ruining the battery.
In 15 years of Lifeline installs, I have never seen this happen, except in controlled lab conditions. I have also never vented any of my Lifeline installations.
Again, I can't address the operating characteristics of any other AGM brand.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Internal Propane Switch Draw Down Battery Charge? roadmama Sprinter and B-van Forum 12 08-27-2015 03:26 PM
Excella 34'- twin bed to full bed conversion??? SilverStone Interior Restoration Forum 0 10-30-2014 04:21 PM
OK to connect a battery charger when the internal one fails? DJW Batteries, Univolts, Converters & Inverters 3 01-06-2014 11:56 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
