Old 04-30-2010, 05:09 PM   #1
Wamego , Kansas
TT Battery Backfeeding TV
Quick (I hope) question:
When I've got the battery in the AS ('73 Overlander) connected to its cables and the umbilical to the TV hooked up, the reverse lights on my truck come on. 2002 K1500 Avalanche if it means anything, which I doubt. Anyone else seen this, and if so, where's the likely culprit? Trailer wiring, fault with brake controller install or bad wiring to the TV connector? Something else?
The result thus far is that when I'm going down the road I have to disconnect the ground cable to the battery and therefor can't recharge the AS battery from the TV's alternator. Bummer.
'Berg
"Ignorance I can deal with. Stupidity is a different matter."
Mark B. is offline   Reply With Quote
Old 04-30-2010, 06:16 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like you have the battery feed line and the backup light line reversed in your trailer plug. The center pin should be the backup lights, and the battery feed should be the one on the top of the plug, next to the wire for the running lights.
do I need a battery nickfxstc Electrical - Systems, Generators, Batteries & Solar 6 02-17-2010 04:32 AM
battery robotwinkie Batteries, Univolts, Converters & Inverters 5 07-10-2009 03:42 PM
Do I need a battery....? jesus mike Batteries, Univolts, Converters & Inverters 4 11-28-2007 09:26 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
