I know my truck's alternator charges my battery while I'm on the road. While I'm plugged into a 30amp hookup, does it also charge then? How about if I'm plugged into a friend's house on a 15 or 20 amp circuit? How about if I'm plugged into my Honda 2000i generator?
I notice that when I'm inside my camper, all set up and plugged into 30 amp/110 power, that my battery indicator will go yellow when I have lotsa 12v things turned on (lights, fan, etc). Does it go yellow or red based upon how much pull is off the battery, or how much charge is left on the battery?
One more... My refridgerator -- when it's running in auto, and the camper is plugged into 110v/30amp power, does it run AUTOMATICALLY off that 110 power? Or do I have to manually switch it? Also, does it even run off 110 at all when it's in Auto? Or does it run off 12v?
Is it better to just leave it in the propane setting and be done with it?
Unless you have a battery isolator between your trailer and tow vehicle, then the battery in your tow vehicle will be charged when the trailer is connected to shore power.
With the frig in Auto, the priority should be 120volts. When shore power is disconnected, it should revert to LP gas.
__________________ History doesn't repeat itself, people do!
Battery charging when plugged in is.
Color what state of charge is, not load.
Auto setting for fridge best is. Only change need to when low amp extension cord using.
Terry Change is inevitable, except from a vending machine
AIR#2611
Mike, technically, AC Delco Deep Cycle batteries are not sealed types...look carefully and you'll see there are vent holes on each end, so these batteries are really classed as 'maintenance free' types - these batteries will leak fluid if you lay them on their sides...the vents allow the flooded cells to 'breath' as the battery heats and cools.
'Sealed' batteries (AGM, GEL, etc) are completely sealed and can be used in any position - they do have one-way vents that will allow the release of hydrogen gas if they are overcharged, but won't leak fluid, as the electrolyte is held against the plates due to it's gelled state.
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated
I don't lay my batteries on their sides, but thanks for the heads up.
Safri-Rick....every once in awhile one gets a nugget, a life long keeper, thats wha i get with the battery life/testing/maintaince of your posting...thanks a million...jack
