Old 06-23-2008, 09:06 AM   #1
iHayley's Avatar
2007 19' Bambi
Portland , Maine
Trying to Understand How My Battery Works
Okay, so here's sorta a dumb question...
I know my truck's alternator charges my battery while I'm on the road. While I'm plugged into a 30amp hookup, does it also charge then? How about if I'm plugged into a friend's house on a 15 or 20 amp circuit? How about if I'm plugged into my Honda 2000i generator?
I notice that when I'm inside my camper, all set up and plugged into 30 amp/110 power, that my battery indicator will go yellow when I have lotsa 12v things turned on (lights, fan, etc). Does it go yellow or red based upon how much pull is off the battery, or how much charge is left on the battery?
One more... My refridgerator -- when it's running in auto, and the camper is plugged into 110v/30amp power, does it run AUTOMATICALLY off that 110 power? Or do I have to manually switch it? Also, does it even run off 110 at all when it's in Auto? Or does it run off 12v?
Is it better to just leave it in the propane setting and be done with it?
Awaiting the jedi masters' sage advice...
Paduwan Hayley
iHayley is offline   Reply With Quote
Old 06-23-2008, 09:34 AM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Unless you have a battery isolator between your trailer and tow vehicle, then the battery in your tow vehicle will be charged when the trailer is connected to shore power.
With the frig in Auto, the priority should be 120volts. When shore power is disconnected, it should revert to LP gas.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-23-2008, 09:37 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yoda says:
Battery charging when plugged in is.
Color what state of charge is, not load.
Auto setting for fridge best is. Only change need to when low amp extension cord using.
Old 06-23-2008, 09:37 AM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Battery Tutorial / Maintenance
After reading several post on batteries, I thought it would be a good idea to post this battery tutorial. Check it out.
Battery Tutorial | Batterystuff.com
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 06-25-2008, 08:31 PM   #5
iHayley's Avatar
2007 19' Bambi
Portland , Maine
You guys ROCK!!! Thank so much for all the info! You are awesome Jedi Masters...!
Old 07-14-2008, 12:50 PM   #6
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Safari - Rick, thanks for the tutorial - one thing I didn't see: Should the batteries be disconnected before filling. Thanks.
willyd is offline   Reply With Quote
Old 07-14-2008, 03:46 PM   #7
Well Preserved
1993 21' Sovereign
It is not necessary, but you can if you feel more comfortable doing it.
Old 07-14-2008, 03:58 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I switched to sealed batteries years ago, AC Delco marine/golf cart/rv:
battery problems solved, I'm almost four years on the current set of three.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 07-14-2008, 08:50 PM   #9
Mexray's Avatar
1978 28' Ambassador
Morada , California
Mike, technically, AC Delco Deep Cycle batteries are not sealed types...look carefully and you'll see there are vent holes on each end, so these batteries are really classed as 'maintenance free' types - these batteries will leak fluid if you lay them on their sides...the vents allow the flooded cells to 'breath' as the battery heats and cools.
'Sealed' batteries (AGM, GEL, etc) are completely sealed and can be used in any position - they do have one-way vents that will allow the release of hydrogen gas if they are overcharged, but won't leak fluid, as the electrolyte is held against the plates due to it's gelled state.
Ray & Pat; Morada, CA
Old 07-14-2008, 10:09 PM   #10
Mike Leary's Avatar
Images: 11
I don't lay my batteries on their sides, but thanks for the heads up.
Old 07-17-2008, 08:27 AM   #11
willyd's Avatar
1993 34' Limited
Thanks for all the good information.
Old 07-19-2008, 05:26 AM   #12
billiards's Avatar
rochester , Minnesota
Safri-Rick....every once in awhile one gets a nugget, a life long keeper, thats wha i get with the battery life/testing/maintaince of your posting...thanks a million...jack
billiards is offline   Reply With Quote
It works garry Off Topic Forum 3 06-30-2006 12:15 AM
Now I think I understand ... guy99 Commercial Listings 23 04-03-2006 02:36 PM
A/C kinda works skidmark Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-27-2005 10:45 PM
Please help me understand what these numbers mean joshua32064 Our Community 18 10-02-2003 07:24 AM
my DC works only sometimes Tomcat Electrical - Systems, Generators, Batteries & Solar 2 04-27-2003 11:26 AM
