Old 06-24-2014, 03:16 PM   #1
1977 31' Sovereign
Indianapolis , Indiana
Truck batteries discharge
Here's the problem:
I hook the hitch up to the AS and my truck batteries seem to discharge. The pig tail is NOT connected...only the hitch ball. It's happened at least 3 times and only takes about an hour for the batteries to need a jump. Truck batteries are in good shape. No problems any other time. Ideas?
Jason
jasonsherman is offline   Reply With Quote
Old 06-24-2014, 03:57 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by jasonsherman View Post
Here's the problem:
Jason
Well, the truck batteries WERE in good shape! If you've run them down to the point you need a jump-start at least three times, maybe not so good anymore.
Question: When you hook up and let it sit, is anything turned on inside the trailer? I ask because when you hitch up the trailer, the trailer and tow vehicle all of a sudden share a common ground because of the metal-to-metal contact at the hitch; both ground to their respective frames and if the frames are connected…
Not having the pigtail connected just means that you haven't powered up the trailer taillights or the brakes. Your problem is not in the trailer taillights or electrically-operated brakes; it's somewhere in the rest of your 12v system.
I know that's not much help, but at least it's a start.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-24-2014, 04:06 PM   #3
1977 31' Sovereign
Thanks. I'm 99% sure nothing's on in the trailer, but will check. If nothing's on in the truck or camper, where's it go? The AS battery doesn't seem to discharge. It sits for weeks without being plugged in and the AS battery is fine. ...strange.
Old 06-24-2014, 04:26 PM   #4
1974 Argosy 20
Kooskia , Idaho
if the pigtail is not connected there is NO possible way that the trailer can run down the truck batteries.
The weight of the trailer on the truck might somehow be causing some other load (short) in the truck wiring which only occurs when the weight is on the ball.
Old 06-24-2014, 05:13 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I agree, I can see no way the trailer can discharge the truck batteries with out a cord plugged in. The common ground would make no difference.
If you leave something on in the trailer the trailer battery would discharge
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-24-2014, 05:20 PM   #6
1977 31' Sovereign
Is there some kind of device or meter I can hook up to the truck batteries to validate my problem?
Old 06-24-2014, 06:11 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You don't suppose somehow the trailer is wired positive ground? As soon as the ball touches the coupler it could start discharging the truck and trailer batteries.
Old 06-24-2014, 06:17 PM   #8
1977 31' Sovereign
Everything works in the trailer...if reversed, I'd have a few problems with convertor, inverters and such. Right?
Old 06-24-2014, 06:58 PM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
That's a long shot that occurred to me also but I can't quite make it work unless the trailer had been redone. More likely something like that could happen with the early 60's
What is the trailer?
13 Ram 2500 TD
Old 06-24-2014, 06:59 PM   #10
1977 31' Sovereign
1977...
Old 06-24-2014, 07:43 PM   #11
Well Preserved
1993 21' Sovereign
It's just barely possible if both the converter and battery were wired reversed it could happen, but it would be a rare thing for everything to work--backwards. Lights would work, water pump would work, furnace fan would run, though little air would come out of the ducts. Easiest way to check for that and confirm it isn't happening is to use a digital volt meter, touch it to the positive terminal of the battery with the + lead touching the positive terminal, and the negative lead touching ground. If you get no reading, try touching the "+" lead to the negative terminal, and repeat the test.
Old 06-24-2014, 08:03 PM   #12
Matthew014's Avatar
2004 25' Safari
Cumming , Georgia
Does your tow vehicle have a load sensing system that is possibly turning on? Have you measured the draw? Knowing how big or small the draw is can sometimes narrow down the possibilities.
Matthew014 is offline   Reply With Quote
Old 06-24-2014, 08:20 PM   #13
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
OK, Its late and I'm thinking off the top of my head again. Is the tongue jack down creating a possible ground path? Yea, It's really not likely, but ground issues are the most common problem in automotive wiring. Is the key in the ignition switch? The Euro cars I work on call this the S contact and any number of things are energized. A weak battery could drop below the required cranking voltage. Hence the need for a jump.
If you've got a DVOM you could try a type of voltage drop test. Before connecting the trailer to the ball set the meter to 20 volts DC and connect one lead to the ball and the other to a good clean metal spot on the tongue. If you've got any voltage +or-, over, say a 1/2 volt there is some kind of interaction between the truck and trailer. However I have no idea what that could be.
Good Luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-25-2014, 07:40 AM   #14
1977 31' Sovereign
Good idea...I will test using the method above. Here's something else: last time I used the electric jack, it has a loose wire. I had to wiggle the wire to get a connection to get the jack working. Do you think this could be the cause of my problems? Or, just an unrelated problem.
battery discharge wolf146 Batteries, Univolts, Converters & Inverters 11 04-24-2010 06:56 AM
78 argosy minuet, black water discharge valve replacement argosy Chuck Waste Systems, Tanks & Totes 5 05-03-2009 04:59 PM
Random Electrical Discharge [A/S 325] Fish36991 General Motorhome Topics 27 02-11-2005 05:39 AM
battery: phantom load, or normal discharge? Chuck Batteries, Univolts, Converters & Inverters 12 08-25-2004 12:13 AM
leaky gaskets in waste discharge jaiman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-01-2003 04:11 PM
