Old 01-25-2010, 06:30 PM   #1
1973 31' Sovereign
Troubleshoot my new converter set up
Hi all.
When I got my trailer none of the 12 volt system was working--a former owner had actually removed the univolt and not replaced it with anything. I bought a new 40 amp converter and 12 v fuse block. I am running the system without a battery as I am always hooked up to shore power (for now).
I am not very experienced with electricity, but I was pretty sure I had everything wired up correctly, plugged the new converter in, and...nothing.
Here's what I did:
1. Ran thick gauge red and black wires from the converter to the fuse panel.
2. Attached all the 12v wires to the fuse panel (purple, brown, etc.)
3. Added 20 amp 12v fuses from an auto supply store.
Am I missing a step here? Any help would be appreciated.
Thanks in advance!
seventythree is offline   Reply With Quote
Old 01-25-2010, 07:03 PM   #2
Originally Posted by seventythree View Post
Hi all.
Here's what I did:
Thanks in advance!
Sounds like you didn't connect to a ground.
What's a "thick gauge" wire??
40 amps is really stretching it for your trailer, as 55 to 60 would be far superior.
At 40 amps, you will be overloading the charger many times. Don't be surprised if it burns out soon.
Running a charger without a battery, is asking for more problems. The battery helps to regulate the voltage. Without the battery, you probably will burn out many light bulbs.
What kind of charger??
Old 01-25-2010, 07:22 PM   #3
1973 31' Sovereign
Oops. It is a 30 amp IOTA converter/charger that i got from best converters. Not grounding could be why it isn't running?
Thanks.
Old 01-25-2010, 07:30 PM   #4
1973 31' Sovereign
Should I run a ground wire from the converter to the fuse panel and then from the fuse panel to the inside trailer wall?
Old 01-25-2010, 07:39 PM   #5
All the 12 volt DC circuits, have a ground for a return wire.
If the negative side is not grounded, then nothing will work.
Your 30 amp charger, will be history in no time.
Sorry.
Old 01-26-2010, 03:35 PM   #6
1973 31' Sovereign
Thanks for the help. I'm going to exchange the 30-amp for a 55 and retry this project in a couple weeks.
Old 01-26-2010, 03:37 PM   #7
Now your talking "real power".
Old 01-26-2010, 03:56 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Enlighten me
I do not follow your logic.
If nothing will work, why will the charger be history? If nothing works, there is no current draw.
A 40 amp charger (as he specified in post #1) is sufficient to power the member's Airstream as it was designed. As no one asked about increased power requirements, why the testosterone about "real power"?
Tom
Old 01-26-2010, 04:30 PM   #9
Tom
Tom.
Airstream discovered the hard way, why Univolts were dying so often.
They switched to higher Univolts that stopped the burnout problems.
Charge the battery, run the water pump, run a few lights, run the furnace and you are way past the 30 amp that might be available.
Keep in mind, in spite of a 30 amp output for a Univolt, that 30 amps is not to be used anyway near the maximum output.
That's why Airstrean finally went to and has stayed with 55 amps.
The 73 manual says that the fuse for the furnace, is 20 amp.
Now the system is performing, without cooking, even if extra batteries are added.
Any power supply that operates at or near full power, will not last very long.
Old 01-26-2010, 04:36 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
I would expect that modern, switching power supplies would be able to run at 100% rated output capacity continuously without failure.
Modern converters are current limited. Older ones were not.
Old 01-26-2010, 05:05 PM   #11
Jimbo
1971 27' Overlander
1968 22' Safari
Chesapeake , Virginia
12V Diagrams
Here is a couple a diagrams that might help you
Jimcollins11 is offline   Reply With Quote
Old 01-27-2010, 08:20 AM   #12
1973 31' Sovereign
Thanks for your help, all.
I'm still a little confused about wiring the system--especially because I'm doing it without a battery for now.
In the bundle of 12v wires there are two thicker white ones, I assume that these are the ground wires. Where do I attach these? Also, where should I run a ground line from the converter to?
Old 01-27-2010, 10:28 AM   #13
Jimbo
1971 27' Overlander
1968 22' Safari
Here is a diagram I made for my A/S. It is a simplified electrical diagram for both 120VAC and 12VDC. Not all airstream are the same, they will differ quite a bit. Hope this helps
Old 01-30-2010, 09:03 PM   #14
New Borockton , Alabama
Images: 21
Running a modern switching converter without a battery will not hurt a thing.
Airstream has a thing for the single stage Parallax and as of yet, I don't kow why.
I might also upgrade to a larger unit but not because it will fail sooner. Never had one claim in 7 years for that. That is just not true.
Jammer is correct, you can run them at max output and it won't hurt anything except if you run out of power which is really not likely even with a 30 amp but you are just limited on charging current.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
converter, wiring, 12 Volt, 12 volt, univolt
Guide to troubleshoot your fridge problem Cristina1966 Refrigerators 4 07-03-2017 08:52 PM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Getting set up BayouFishin Member Introductions 14 08-24-2008 06:25 AM
Then depression set in.... till General Repair Forum 19 10-01-2004 09:42 AM
hitch set-up? remark83 Hitches, Couplers & Balls 3 05-16-2003 06:24 PM
